General Centre of mass derivation
The discussion focuses on deriving the center of mass for a triangle positioned symmetrically on the X-axis, with a base of length b and height H. The approach involves treating the triangle as a series of 1D bodies and using integration to find the y-coordinate of the center of gravity. Since the triangle is symmetric, the y-coordinate can be calculated using the formula for the center of gravity, factoring out the constant density. The coordinate system is set with the origin at the center of the base, simplifying the determination of the equations for the triangle's slant sides. This method leads to identifying the centroid as the center of gravity for the triangle.
shaggySS
Hello,
It's my first question here. So I'll try to give as much as information as I know
Actually I am stuck with a problem of centre of mass derivation of a triangle with its base on the X axis and symmetric about it.
The base is b and height is H
As far as I know I have to imagine it as a couple of 1d bodies and integrate them.
Thanks
SAGNIK
Since its symmetric about the X axis the y coordinate needs to be found only.
The y- coordinate of the center of gravity of an object with density function \delta(x,y) is
\frac{\int y \delta(x,y) dxdy}{\int \delta(x, y) dxdy}
In particular, if \delta is a constant, it can be factored out of the two integrals and cancelled- that is the "center of gravity" is just the
geometrical "centroid". Here, we can set up a coordinate system so that the origin is at the center of the base of the isosceles triangle, base
along the x- axis, height along the y-axis. The equations of the two slant sides can easily be determined.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
