General sign notation for mathematical elements
37 replies · 7K views
ferman
As we have seen some mathematical sign lately in this group, because I put you in the drawing of the general sign of any element.
You also can see more searching “from zero to infinite, ferman”.
Thank you.
Mathematics news on Phys.org
Calling them symbols does not make nonsense anything but nonsense!
[tex]\frac{0}{0}[/tex] is NOT 1, it is not defined at all .
[tex]\frac{\infty}{\infty}[/tex] is NOT 1, it is not defined at all.
Well, perhaps is time to change erronous concepts.
"Any element divided by itself gives us the unit 1". If not, these elements aren't equal or equivalent.
It is not correct to explain properties of division with properties of multiplication, we have to do with properties of division.
You need to look up the definition of division. It's defined for real numbers a,b and c, as a/b=c iff a=bc and b!=0.
Yes, let's please change that erroneous concept:
"Any element divided by itself gives us the unit 1" is an erroneous concept. Please change it!
"It is not correct to explain properties of division with properties of multiplication, we have to do with properties of division."
Because you SAY so? Perhaps you should explain what YOUR definition of "division" is.
(Dang, Cristo got in just ahead of me!)
Okay, let us bear with ferman for a while!
We introduce a mapping from R2 to R called "D", having the basic property of
D(a,a)=1, for all a in R.
That is valid starting point.
What other properties should D have, ferman?
To help you out, ferman:
If "*" stands for multiplication,
should we have the rule D(a,b)=a*D(1,b) for all a and b in R?
ferman: you can certainly define your own division symbol to have the property that x/x=1 for all x. But that does not guarantee that it has anything to do with division as used by mathematics. (In fact, it guarantees that your definition will be incompatable with most mathematical division operations)
For other posters:
According to ferman's website, we also have the rule
D(a,D(a,b))=b
Do we have rules like IF D(a,b)=D(a,c), THEN b=c, ferman?
i don't understand why people do this. attention seeking on the internet, here of all places
ferman:
Should we have the rule
D(a+b,c)=D(a,c)+D(b,c), that is: [tex]\frac{a+b}{c}=\frac{a}{c}+\frac{b}{c}[/tex]?
Well friends, I think I am right.
To explain my viewpoints, I put you a summary of this question with a drawing (important for comprehension). This you also can see in the end of my web, "fron zero to infinite, of ferman".
When we operate with empty sets, we usually look on (simple and exclusively) the result of their component elements to which we date as zero when having none.
But we forget something essential, and it is the number of empty sets with which we are operating.
If, as in the drawing, we take an empty glass to which we multiply by 3, the real result will be we have 3 empty glasses, but the partial result will be we have zero elements in these 3 empty glasses.
So, in this case we adjust as result ALONE THEIR ELEMENTS, but we forget we are USING A SERIES OF SETS.
Although this operation method is of great importance due to we later use this property as principle, base and justification of other operations, as can be in division.
And clear, when taking as principle and explanation to a partial result and not to the total result of the operation, because we end up accepting indetermination principles that are not correct.
For example, if we put 1x0 = 4x0 we are accepting that both terms are identical, when they are not because in the first term there is alone an empty set and the second term there are four empty sets, although the number of component elements is same in both term of the equality.
This way, when we operate (3x0 = 0) we should accept that we are operating PARTIALLY and alone with relation to the elements of the empty sets that we are using.
In the same way we should accept that this operation is PARTIALLY UNCERTAIN, since three empty sets cannot be the same thing that an empty set.
For this same reason we cannot use this type of postulates to conclude that 0/0 are an uncertain operation, since their solution is 0/0=1 abiding to the properties of the division.
Just a load of blather.
I have asked you several specific questions as to how your "division" interacts with other arithmetic operations, now start answering them.
Well, this would be the main property of division:
Equivalence principle:
"In any division the dividend contains N times to the quotient, being N the divider."
In this sense, the current conclusion as for 0/0 is uncertain, and so any number could be the result of this division seen to be clearly incorrect. Question that we can see with any example:
If were 0/0 = 7 then we would have that the dividend ( 0 ) should be seven times superior than the divider ( also 0 ) and this is not this way since they are the same one.
Don't worry, I'll treat to response all them. Time to do.
Again, mere silly blather about "correctness".
I have already taken into account your desire to have a "D" mapping satisfying the basic principle D(a,a)=1 for all a in R.
What of the other properties I've mentioned does D have?
Doesn't this contradict what you initially said, "It is not correct to explain properties of division with properties of multiplication, we have to do with properties of division" since you are now DEFINING division in terms of multiplication?
Now, you are going to have to tell us what you mean by "seven times superior than the divider". I don't believe "superior" is standard mathematics notation.
While I might be getting lost in the grammatical intricacies of "so any number could be the result of this division seen to be clearly incorrect" (isn't there a verb missing from this clause?), if I am interpreting this correctly you seem to be now agreeing with what I said and contradicting the assertion on your website that 0/0= 1.
Besides, 0=0+0+0+0+0+0+0=7*0, that is, 0 IS 7 times "superior" than itself..:wink:
Well, perhaps I find very complicated some of your questions.
My rule or main property of division is very easy:
Given a, b and c that can be any type of number (or elements) the division a/b=c is correct "when a contain b time to c".
6/3=2 6 contains 3 time to 2
8d/2=4d 8d contain 2 time to 4d
d/4 = h d contains 4 time to h
S/1 = S S contains 1 time to S
Now well, when is the same o equivalent element that is divided by the same one, we obtain the pure unit without no one type of qualification.
6/6 give us 1
0,01/0’01 give us 1
h/h give us 1
@/@ give us 1
x/x give us 1
All this propitiated by the commutive property of division (second property): " En any division we can change the dividend by the quotient being also fulfilled the new resultant equality"
6/3=2 --------- 6/2=3
S/1=S --------- S/S=1
Sorry for not understand well your other proposals.
As I have already stated, you wish D to have the property D(a,D(a,b))=b.
Fine. You are entitled to that. Now go on.
You say:
This is what now matematics say, but not what I say.
I say 0=0+0+0+0+0+0+0 is not equal. 0 = 7*0 is not equal.
ferman said:
You say:
Okay, so you now wish to change the definition of 0 as well, not only "division".
ferman said:
Thank you for listen to me.
It won't last long, I assure you, unless you make an effort to be intelligible.
assume 0/0 = 1. then n*(0/0) = (n*0)/0 = 0/0 = n*1 = n. so 0/0 = n, too.
When we have division by 0, 3/0, 6/0, etc. we always obtain solution we limit infinite, but when we have the division between equal values 0/0 , a/a, @/@ etc. we obtain as result the unit 1.
This is due the dividend and divider are the same, with the same value.
Then we have that uniquely when we divide 0/0 is when we obtain a determinate value, 1.
This circumstance obliges us to resolve before the question 0/0 and later resolve the other operations.
Then we can say that: the 0/0 have priority on the other operations, with object of not produce indeterminate operations as 3/0, 8/0 N/0, etc.
Then your example would be:
N*0/0 = N*1 = N
This is perfectly logical due to if we multiply a number N by other 0 and immediately we divide N by the same 0, the number N can’t change its value.
Although the current viewpoint where N*0/0 = 0/0 is not consequent with lo logic and comprehension, due to if we multiply N by 0 and divide by 0 at the same time, the value of N change to indeterminate. Not logic. Alone erroneous rules of multiplication can drive us to this conclusion.
As you can see, is the unique case (0/0) in that the division by 0 give us a determinate solution.
I think you should replace the "we" in your post with "I." Division by zero is undefined, as has been explained to you above, in the "usual" number systems.
You are right. It is with.
Well, regarding this topic and my work on it, I would like insert a new drawing for representation of the empty sets.
Sure you don't agree with it, but is my viewpoint on this theme.
Out of curiousity, are you using this new concept of division to help you build a perpetual motion machine?
Well, as joke is good.
No, my intention is give worth to division as mathematic operation with its own entity and not as succedaneum of multiplication.
We have to remember that multiplication and division have different properties, so we can’t express and explain division with properties of multiplication.
This case I bet for particular properties for division as the Equivalence principle or the Commutive property.
Thank you.
