General solution to system of equations and initial value problem
paperweight11
Find the general solution for the following systems of equations, a solution to the
initial value problem and plot the phase portrait.
--> this is in matrix formx' =
1 2
0 3
all multiplied by x.
also, x(0) =
Determinant, etc.
I first use the eigen values and get it to:
eigenvalue1 = 1; eigenvalue2= 3
however, when I start with 1, my matrix is pretty screwed up:
0 2
0 2
So when I'm trying to figure out the values for the eigenvector I am confused. I don't know what to put it as.
Any help would be appreciated. Thanks.
hi paperweight11! :smile:
how did you get those? :confused:
(those would be the eigenvalues for 1,0,,0,3)
They are also the eigenvalues for
[tex]\begin{bmatrix} 1 & 2 \\ 0 & 3\end{bmatrix}[/tex]
since the characteristic equation is just
[tex]\left|\begin{array}{cc}1- \lambda & 2 \\ 0 & 3- \lambda\end{array}\right|= (1- \lambda)(3- \lambda)= 0[/tex]
(The eigenvalues for any triangular matrix are just the values on the diagonal.)
The eigenvectors must satisfy
[tex]\begin{bmatrix}1 & 2 \\ 0 & 3\end{bmatrix}\begin{bmatrix}x \\ y \end{bmatrix}= \begin{bmatrix}x \\ y\end{bmatrix}[/tex]
so x+ 2y= x and y= y. x+ 2y= x reduces to y= 0 which gives <1, 0> as an eigenvector, and
[tex]\begin{bmatrix}1 & 2 \\ 0 & 3\end{bmatrix}\begin{bmatrix}x \\ y \end{bmatrix}= \begin{bmatrix}3x \\ 3y\end{bmatrix}[/tex]
so x+ 2y= 3x and 3y= 3y so that y= x which gives <1, 1> as an eigenvector.
( Your
0 2
0 2
is the same as 2y= 0 so the eigenvector is <1, 0>.)
