Proving the Geometric Series with Variable Coefficients: A Scientific Approach
The forum discussion centers on proving the inequality of a geometric series with variable coefficients, specifically showing that the summation of the series \( r^n + 2r^n + 3r^n + \ldots + nr^n \) is less than \( \frac{r}{1 - r^3} \) for \( n > 1 \) and \( 0 < r < 1 \). Participants clarify the correct formulation of the series, which simplifies to \( \frac{n(n+1)r^n}{2} \). The proof involves manipulating the series and applying properties of geometric progressions, ultimately demonstrating that the left-hand side is negative, thus confirming the inequality.
  • Understanding of geometric series and their summation formulas.
  • Familiarity with mathematical notation, particularly summation and inequalities.
  • Knowledge of the properties of limits and convergence for series.
  • Basic algebraic manipulation skills for handling inequalities and series.
  • Study the derivation of the geometric series sum formula \( S = \frac{a(1 - r^n)}{1 - r} \).
  • Learn about convergence criteria for series, particularly for geometric series with \( 0 < r < 1 \).
  • Explore advanced techniques in mathematical proofs, focusing on inequalities and series.
  • Investigate the application of summation notation and its manipulation in mathematical proofs.
Mathematicians, students studying calculus or algebra, and anyone interested in understanding series and their properties, particularly in the context of inequalities and proofs.
jisbon
Show that summation of r^n+2r^n+3r^n+...nr^n is less than r/(1-r^3) for n more than one.
So this seems to be a geometric Series, but with the coefficients in front, how do I exactly go about proving this?
Thanks
Are you sure you did write the question down correctly? As it stands,$$r^n + 2r^n + 3r^n + \dots + nr^n = r^n (1+2+3+ \dots + n) = \frac{n(n+1)r^n}{2}$$which doesn't appear to be what is intended.
It is correct, but how does one prove that it is lesser than r/(1-r^3)
It's not; that's why I presumed the question was written down incorrectly, or otherwise that the question itself is wrong.
I've DMed you the question, and it seems to be exactly what I written down here
It's certainly not the same question, because you have ignored all of the terms except the final line... :wink:
etotheipi said:
It's certainly not the same question:
Isn't this proving the summation of r^n + 2r^n + ... is less than r/(1-r^3) ?
No, because that is a necessary condition, but not a sufficient condition!
Also note that we now know the key bit of information, that ##0 < r < 1##! Without this, the question would not make any sense.
Hmm okay, so how do I start about proving this? I tried dividing the hint given by (1-r) again to make both similar, but I can't seem to get the gist of it
What about ##r = 0.5##, ##n = 2## or ##n = 3## or ##n = 4##?
As in computing them?
With r=0.5, it would seem impossible to compute out the equations, but it does converge eventually. Could you kindly advice me how to compute? (I was thinking r>1 all along)
I would start with noticing that $$\begin{align*}
S = &+ 1(r + r^2 + r^3 + \dots + r^n) \\
&+ 2(r^2 + r^3 + r^4 + \dots + r^n) \\
&+ 3(r^3 + r^4 + r^5 + \dots + r^n) \\
&+ \dots \\
&+ nr^n
\end{align*}$$Notice that this can be simplified using the formulae for geometric progressions to$$S = \frac{r(r^n -1)}{r-1} + 2\frac{r^2(r^{n-1} -1)}{r-1} + \dots + n\frac{r^n(r^1 - 1)}{r-1}$$ $$S = \frac{1}{r-1} \left[ (r^{n+1} - r) + (2r^{n+1} - 2r^2) + (3r^{n+1} - 3r^3) + \dots + (nr^{n+1} - nr^n) \right]$$ $$S = \frac{1}{r-1} \left[ r^{n+1}(1+2+3+ \dots + n) - (r + 2r^2 + 3r^3 + \dots + nr^n) \right]$$ $$S = \frac{n(n+1)}{2} \frac{r^{n+1}}{r-1} - \frac{(r + 2r^2 + 3r^3 + \dots + nr^n)}{r-1}$$Note that for ##0 < r < 1##, the first term is less than zero... play around with this, and see if you can get it in the right form!
If ##r > 1##, then the right hand side is negative: ##1- r^3## is negative.
There's no convergence, as it's a fixed ##n##.
&+ \dots \\
&+ n(r^n)
Hmm, I don't seem to see the relation at the start. How does one get +1(r+r^2+r^3+...r^n) ?
I just listed out all of the terms. ##S## is equal to the whole sum, not just that line.
Yes I understand you have listed all the terms out with also +2(...) and +3(...), but I can't seem to see why it is listed as so though. (Can't seem to get the pattern)
Each line in that sum is a column in the original problem statement!
Oh no, I think I know why. I might have misread the question (thinking that they want the sum of 1 line instead of all the lines :/ Will reread the question now, will reply back if I have any additional queries. Thanks for the correction.
Rules Violation: Member warned about providing too much help
To give a further hint, we deduced that$$S = \frac{n(n+1)}{2} \frac{r^{n+1}}{r-1} - \frac{(r + 2r^2 + 3r^3 + \dots + nr^n)}{r-1}$$Add ##\frac{r}{(r-1)^3}## to both sides,$$\begin{align*}S + \frac{r}{(r-1)^3} &= \frac{n(n+1)}{2} \frac{r^{n+1}}{r-1} + \frac{1}{(r-1)} \left[ \frac{r}{(r-1)^2} - (r + 2r^2 + 3r^3 + \dots + nr^n) \right] \\ \\
&=\frac{n(n+1)}{2} \frac{r^{n+1}}{r-1} + \frac{1}{(r-1)} \left[ \frac{r}{(r-1)^2} - \sum_{i=1}^n ir^i \right]
\end{align*}$$What can you say about the RHS?
RHS:
(less than 0) + (negative number)(positive-negative) =
(less than 0) + (negative number)(positive) =
(less than 0) + (negative number) =
(negative number)
So do you see how the proof concludes?
So if S + r/(r-1)^3 is negative, minus r/(r-1)^3 on both sides, I get S = some negative number - r/(r-1)^3...
How is S less than - r/(r-1)^3 ?
Also, I was taught that the formula for GP is (1-r^(n+1)) / 1-r, can this still apply?
Essentially yes; if the RHS is negative, then so is the LHS (they're equal!). We can write$$S + \frac{r}{(r-1)^3} < 0$$ $$S < \frac{-r}{(r-1)^3} = \frac{r}{(1-r)^3}$$which is what we set out to prove.
I don't think that's right. What do you mean by 'formula for GP'? The sum of the first ##n## terms of a GP with first term ##a## and common ratio ##r## is$$S = \frac{a(1-r^n)}{1-r} = \frac{a(r^n - 1)}{r-1}$$but that's not what you wrote.
Understood your first portion, thanks a lot :)
Regarding GP, what I meant was the formula for geometric series sorry. I was taught that
Regarding GP, what I meant was the formula for geometric series sorry. I was taught thatView attachment 268703
That's also fine. In my experience it's more common to start counting from ##u_1##, i.e. to consider ##S = \sum_{j = 1}^n ar^{j-1} = \frac{a(1-r^n)}{1-r}##, but there's nothing wrong at all with shifting ##k = j-1## to find ##S = \sum_{k = 0}^{n-1} ar^k = \frac{a(1-r^n)}{1-r}##
I did it quite similarly to @etotheipi. My starting point was to make the sum vertically (your picture).
$$S=\sum_{j=1}^nj\left(\sum_{i=j}^nr^i\right)$$
I know how to compute a geometric sum from ##i=0## up to some number, but here I want to start from some arbitrary index, so my plan is to make two sums starting from ##i=0##, but with one ending at ##i=n##, and the other at ##i=j-1##, then subtract both
$$\begin{align*}
S&=\sum_{j=1}^nj\left(\sum_{i=0}^{n}r^i-\sum_{i=0}^{j-1}r^i\right)\\
&=\sum_{j=1}^nj\left(\frac{1-r^{n+1}}{1-r}-\frac{1-r^j}{1-r}\right)\\
&=\sum_{j=1}^nj\left(\frac{r^j-r^{n+1}}{1-r}\right)\\
&=\left(\sum_{j=1}^n\frac{jr^j}{1-r}\right)-\left(\frac{r^{n+1}}{1-r}\sum_{j=1}^nj\right)
\end{align*}$$
Since ##0<r<1##, I know that the second parenthesis is positive because ##1-r>0##, and so
$$S=\left(\sum_{j=1}^n\frac{jr^j}{1-r}\right)-\left(\frac{r^{n+1}}{1-r}\sum_{j=1}^nj\right)<\sum_{j=1}^n\frac{jr^j}{1-r}$$
If you remove something from a positive number, then, of course, that positive number is bigger than the result of that operation.
Using the hint, we get
$$\sum_{j=1}^njr^j<\frac{r}{(1-r)^2}\Leftrightarrow S<\frac{1}{1-r}\sum_{j=1}^njr^j=\sum_{j=1}^n\frac{jr^j}{1-r}<\frac{r}{(1-r)^3}$$
Can someone tell me why I rewrote what @etotheipi posted? :oldconfused:
I'm amazed by myself. o_O
  • Haha
I think yours is an improvement; the sigma notation makes everything much more compact.
etotheipi said:
Nice! There is a very tiny typo, that the first formula should I think be$$S=\sum_{j=1}^nj\left(\sum_{i\geq j}^nr^i\right)$$
I think that we can write ##i=j##. I did a quick google search and have found someone else using it like that.
Not very convincing, but yeah. :blushing:
Sorry, no you're right. I missed the upper index! :doh:
  • Haha
