Geometry question -- several lines through parallelograms
  • Thread starter Thread starter geoffrey159
    Geometry Lines
The problem involves a parallelogram \(ABCD\) with two lines \(EF\) and \(GH\) parallel to its sides. The objective is to demonstrate that the lines \(EB\), \(HD\), and \(IC\) either intersect at a common point \(M\) or are parallel. The discussion revolves around geometric properties and relationships within the context of parallelograms.
  • Participants explore various methods, including coordinate systems and geometric projections. Some express uncertainty about the clarity of certain terms and concepts, such as the orientation of parallelograms. Others suggest simplifying the problem by considering rectangles instead of parallelograms.
The discussion is active, with participants offering insights and alternative perspectives. Some have proposed algebraic approaches, while others are questioning the assumptions underlying the problem. There is an ongoing exploration of the implications of different geometric interpretations.
Participants note the potential complexity of the problem and the varying levels of understanding regarding the geometric concepts involved. There are references to theorems and geometric properties that may or may not apply to the current problem setup.
geoffrey159
On the picture, ##ABCD## is a parallelogram, ##(EF) // (AB) ##, and ##(GH) // (BC)##.
The problem is : show that lines ##(EB)##, ##(HD)##, and ##(IC)## either all meet in ##M##, or are parallel.
I've solved the problem introducing a coordinate system ##(D,\vec {DG},\vec {DA} )##, but this was the 'last chance' idea. I don't like it too much, it is a little messy, and I suspect there are simple ideas that could be used and that I didn't see. So my demand is rather for insights. How would you solve it ? Thanks !
Parall AHGD less parall ABFE equals parall BCKJ. Three parallelograms similarly oriented in the plan; and adjoining neighbors. To find point J, just extend linear segment IC across segment AB. Side JK of the third parallelogram, is parallel to side BC. Any such a trio of parallelograms, induces a commun point of one of their respective diagonals. A theorem to be proven.
Hello. Thank you for your post.
What does parallelogram AHGD less parallelogram ABFE mean ? Can you draw a picture ?
What should be understood by orientation of several parallelograms ? I don't understand this.
It is possible after all that I understood nothing of what you said :-), but aren't you paraphrasing the problem statement ?
You can simplify the geometry by thinking about plane projections.
What do you mean ? You may give your detailed solution as the exercise is already solved, it's just that I really feel that mine is longer than it needs to be.
It consists in fitting a coordinate system on the parallelogram, finding the cartesian equations of (EB), (HD), and (IC), and start working on the following alternative: two of these lines either meet at a point or are parallel. This alternative translates algebraically when one tries to solve the system of their cartesian equations.
If this algebraic condition is satisfied then the solution of the system is also a point of the third line, if not, they are mutually parallel.
If you take a photograph of a rectangle, but not square on, you get a parallelogram. You can reverse that by a suitable plane projection to convert a parallelogram to a rectangle. Straight lines are conserved, so without loss of generality you can consider only the case in which the shapes are rectangles.
However, I don't know whether that helps much. I suppose it would help with the algebraic approach.
I endeed simplified my sketches by switching to the Euclidean geometry, from the projective geometry. The transformation is legal, and would not affect the issue.
Intuititively, I understand the idea, but I don't immediately see how it simplifies the problem. In my mind, it amounts to replace the word 'parallelogram' by the word 'rectangle' in the problem statement.
erratum: "Parall AHGD less parall ABFE equals" is replaced, sorry for my mistake, by "We will construct" .
addendum: Let's switch to Euclidean geometry, in order to see rectangles; and let's remember the proven theorem that states that in any hexagon circumscribing/confining a circle, three diagonals are either concurrent or parallel. In our problem, in both projective and Euclidean geometries, two sides of any possible hexagon are always in a straight continuity (angle is 180 degrees). This criterion makes the "or are parallel" of the conjecture presented by Jeoffrey159, not receivable. If the audience accept the following simple proof based on the notion of order (term used in philosophy of mathematics), his conjecture becomes a new theorem. THE HARMONIC MEAN OF THE THREE DIAGONALS IS A CONSTANTE. A correlation to what happens in the above mentioned hexagon confining a circle, needs be done. The idea must be developped and the result could be translated in Bourbak's language & spirit, for purpose of publication.
@theBin : it is just a high school problem that I tried to brush up on my geometry, so it doesn't need advanced geometry to be solved.
However, you say that the 'or parallel' statement is wrong, but it's not what I find (by the means I used).
Continuing the idea, we can normalise the outermost rectangle to a unit square. So now there is only pair of variables, the coordinates of the interior point. Certainly the algebra is now fairly straightforward. Similar triangles produce three equations relating this (x,y) to the coordinates of the intersection point, and it is easy to see that one can be deduced from the other two. I was hoping this would lead to some insight regarding the geometric argument, but I don't see it yet.
By the written & graphic informations you presented, it is clear that your three diagonals have different orientations/angles. May I challenge you to present/show a case where three diagonals are parallel ?
Since there are more than one unknown, a complete solution would also contain other stuff, like an arithgmetic and a geometric means. I abandon this problem which is beyond my capacities and education.
That is not quite the point. There may be a not too difficult method which shows that either they intersect at a common point or are all three parallel. But it might require a more elaborate proof to rule out the parallel case.
As I wrote in post #11, if you accept the validity of my simplification-by-projection arguments, the algebra is not at all difficult. I'm happy to help you through it.
Labelling the vertices A, B, C left to right across the top, D, E, F across the middle, etc., ACIG forms a square. Make it a unit square with G as origin. Point E has coordinates (x,y), and the point of intersection of CD and BG is (u,v). Use similar triangles to express u and v in terms of x and y. Etc.
@theBin: Honestly you are attracting attention for nothing and I don't like it.
As I said, it is a high school problem, and anyone that knows two or three things about line intersections can get to the same result I got to, in minutes, following the process described in a previous post. So before the next angry post, I suggest you do it with simple methods and tell me weather it is possible or not.
Thread closed temporarily for Moderation...
  • · Replies 17 ·
