Get rid of excess volts/current
  • Thread starter Thread starter tribalsurfer
The discussion focuses on eliminating an excess voltage of 0.01V that inadvertently activates a gate connected to a phone. Tribalsurfer clarifies that 0.01V is voltage, not current, and suggests using a transistor with a higher turn-on voltage if applicable. Additionally, a voltage divider can be implemented to reduce the voltage to 0.002V, ensuring that the gate remains inactive during phone rings.
  • Understanding of voltage and current concepts
  • Familiarity with transistor types, specifically JFET and MOSFET
  • Knowledge of voltage divider circuits
  • Basic electronics principles
  • Research how to select transistors based on turn-on voltage specifications
  • Learn about designing voltage divider circuits for signal attenuation
  • Explore the characteristics and applications of JFET and MOSFET transistors
  • Investigate methods for filtering unwanted voltage signals in electronic circuits
Electronics enthusiasts, circuit designers, and anyone troubleshooting voltage issues in electronic devices.
tribalsurfer
Hi
I have my gate hooked up to my phone. The problem i have is the phone always has an extra current of 0.01V and that activates the gate. I need to get rid of that current on the wire before it reaches the activator for the gate when the phone rings.
So when the phone rings the gate opens. How do i get rid of that extra 0.01v or current
Thank you in advance
cheers ;-)
Tribalsurfer
0.01V is voltage, not current! What is gate? Is it the gate of a JFET or MOSFET. If it is one of those transistor, just change to one with higher turn on voltage! If you are not referring to a transistor, then I don't even know what you are talking about.
Ringing voltage is quite, you can always put a voltage divider in front of what ever gate you are talking about. A divide by 5 divider will change the voltage to 0.002V. When the ring is on, it should be in volts( I don't remember anymore), so even with a divide by 5, you still get over a volt.
  • · Replies 42 ·
  • · Replies 19 ·
