Getting Rid of Negative Exponent
  • Thread starter Thread starter bmed90
    Exponent Negative
The discussion focuses on solving a separable differential equation where the participant encounters the term y^(-2). To eliminate the negative exponent, it is established that y^(-2) can be rewritten as 1/y^2. By inverting both sides, the equation transforms into 1/y^2 = -2(x + x^2/2). The final steps involve recognizing that y^2 = 1/A leads to y = √(1/A), clarifying the process of handling negative exponents in differential equations.
  • Understanding of separable differential equations
  • Knowledge of exponent rules and manipulation
  • Familiarity with basic calculus concepts, particularly derivatives
  • Ability to perform algebraic operations involving square roots
  • Study the process of solving separable differential equations in detail
  • Learn about manipulating exponents and their properties
  • Explore the concept of derivatives, specifically dy/dx and its notation
  • Review algebraic techniques for solving equations involving square roots
Students studying calculus, particularly those tackling differential equations, as well as educators seeking to clarify exponent manipulation in mathematical contexts.
bmed90
Getting Rid of Negative Exponent!
So I am solving a Diff Eq ( separable equation) and I am down the the last step. After integrating both sives and solving for y I am left with y^(-2) on the left hand side. How do I finalize it and get rid of negative 2 expononent?
y^(-2)=-2(x+x^(2)/2)
y^(-2) is the same as 1/y2, so just write it as that and invert both sides.
So you invert both sides, then what? do you take the square root of both sides and invert back to y^(-1)??
Also, is y' understood to be d/dy or dy/dx?
if you invert 1/y2 you will get y2 then you can take the square root if you wish.
Usually it is dy/dx.
Ok I don't think you understand
Say you have y^(-2)=(something), how do I get to... y=(something)
If you invert y^(-2) you get 1/y^(+2) ...yes ...but then what ...take square root? that would leave you with 1/y on left... Then invert both sides again? so it would end up being y= sqrt(something)also how do you know when y' is indeed dy/dx and not d/dy
I meant that y-2 is the same as 1/y2, so you have
1/y2 = -2(x+x^(2)/2) (I am not exactly sure how you have a negative sign, so you may need to check that part over)
and if you have 1/y2 = A, then y2 = A and so y = √ A
y' is usually used to denote the first derivative. d/dy is just write as that, d/dy.
How is this possible1/y2 = A, then y2 = A and so y = √ A
oops, sorry about that, typo, it should read:
1/y2 = A, then y2 = 1/A and so y = √(1/A)
