Getting Started with Spline Fit in Matlab
  • Context: MATLAB
  • Thread starter Thread starter Arman777
    Fit Matlab
22 replies · 3K views
Arman777
Insights Author
Hi Everyone
I am Arman.I am at first grade in Physics and I have trouble to understand Matlab.Now we did Energy Conservation Experiment.I draw x-t and F-t graphs using matlab.Instructor told us we should use spline fit to draw a F-t graph.I don't have a toolbox about it.She told us some code like
"hh=(xx,...)"
It was something like this I don't remember exactly.How can I do that.I can send my graph codes If its necessery.
Sincerely Arman
Thank you. But I have some trouble again.
Why are you trying to spline F with respect to x? In the OP, you say you are working with F vs t.
You mean that you plot force vs position, and you need to fit that curve? If that is the case, are all the values of x distinct?
I have f-t and x-t grpahs and I want to make F-x.But When we want to make to grapsh together there will be a time difference.I mean let's suppose x-t graph is t=0.34 x=1.5 but in F-t graph t=0.35 F=1.5 so the time difference should be fixed and spline fit makes that thing I guess.
.Basically I want to plot F-x Graph using F-t and x-t graph and spline fit
If I can't I will going to just take F and x and put them.Which not correct put Its fine enough ??
Then what you want to do is to spline F at the same points in time as x.
FF = spline(t,F,xx)
what will be that plot code
"yy = spline(x,y,xx);
plot(x,y,'o',xx,yy)"
Example in the Mathlab
My idea
FF = spline(t,F,xx)
plot(t,F,'o',xx,FF)
Arman777 said:
plot(t,F,'o',xx,FF)
That will give you F vs t, not F vs x. Now that you have FF at the same points in time as x, you can plot
plot(x,F)
there's one problem again
1)I don't have 400 N but it still writes 400 N I don't know why ?
By the way thanks
It doesn't work because you are extrapolating data outside the time range of the force measurements. I don't understand how come you have position data at such different times than force data.
>> t=position_time(:,1);
>> x=position_time(:,2);
>> t=force_time(:,1);
>> F=force_time(:,2);
>> tt=0.8:3.1;
>> tt=0.8:0.1:3.1
FF=spline(t,F,tt);
>> plot(x,F);
It worked I can send the image its consist with the result.Thank you
Is it consist with the two graph that I send you ?
And I have a problem My graph says the work done is 0.26 J using trapz code.
I calculated the ΔKE=1/2mΔv2 Which gave me 0.42 J
and the real result using mgsinθx=W gave me 0.34 J
It means theoritaical value is 0.34 J , my experimental graph value is 0.26 J , experimental speed value is 0.42 J
There will be a friction and ΔKE-Wf=0.26J so 0.16 J gone to friction maybe ??
But there's also friction that we didnt reduce from experimental value which I thing that means I found the result with %10-15 error
Is that ok ?
