MATLAB Getting Started with Spline Fit in Matlab
  • Thread starter Thread starter Arman777
    Fit Matlab
Arman is learning to use Matlab for plotting graphs related to an Energy Conservation Experiment, specifically needing help with spline fitting to create a force vs. position graph from force vs. time and position vs. time data. He initially confused the variables but clarified that he wants to plot force against position, not time. After receiving guidance, he successfully implemented spline fitting but encountered issues with extrapolated data and discrepancies in calculated work done, leading to questions about potential friction affecting his results. The discussion highlights the importance of ensuring data consistency and understanding the implications of experimental errors. Overall, Arman is seeking clarification on his findings and the accuracy of his experimental results.
Arman777
Insights Author
Hi Everyone
I am Arman.I am at first grade in Physics and I have trouble to understand Matlab.Now we did Energy Conservation Experiment.I draw x-t and F-t graphs using matlab.Instructor told us we should use spline fit to draw a F-t graph.I don't have a toolbox about it.She told us some code like
"hh=(xx,...)"
It was something like this I don't remember exactly.How can I do that.I can send my graph codes If its necessery.
Sincerely Arman
Thank you. But I have some trouble again.
You don't have the same number of values of x as you have of F.
I have again problem.
Why are you trying to spline F with respect to x? In the OP, you say you are working with F vs t.
I should draw Fx so so sorry
My foolish mistake If you can help me I ll be glad.
You mean that you plot force vs position, and you need to fit that curve? If that is the case, are all the values of x distinct?
I have f-t and x-t grpahs and I want to make F-x.But When we want to make to grapsh together there will be a time difference.I mean let's suppose x-t graph is t=0.34 x=1.5 but in F-t graph t=0.35 F=1.5 so the time difference should be fixed and spline fit makes that thing I guess.
.Basically I want to plot F-x Graph using F-t and x-t graph and spline fit
If I can't I will going to just take F and x and put them.Which not correct put Its fine enough ??
Then what you want to do is to spline F at the same points in time as x.
FF = spline(t,F,xx)
Likes Arman777
It worked but graph is so nonsense.I don't know why ?
what will be that plot code
"yy = spline(x,y,xx);
plot(x,y,'o',xx,yy)"
Example in the Mathlab
My idea
FF = spline(t,F,xx)
plot(t,F,'o',xx,FF)
Arman777 said:
plot(t,F,'o',xx,FF)
That will give you F vs t, not F vs x. Now that you have FF at the same points in time as x, you can plot
plot(x,F)
Likes Arman777
Theres one problem again
1)I don't have 400 N but it still writes 400 N I don't know why ?
By the way thanks
Could you show the plot
plot(t,F,'o',xx,FF)
ok
It doesn't work because you are extrapolating data outside the time range of the force measurements. I don't understand how come you have position data at such different times than force data.
Let me send my data graphs each of them.And Data.If you want you can look.
>> t=position_time(:,1);
>> x=position_time(:,2);
>> t=force_time(:,1);
>> F=force_time(:,2);
>> tt=0.8:3.1;
>> tt=0.8:0.1:3.1
FF=spline(t,F,tt);
>> plot(x,F);
It worked I can send the image its consist with the result.Thank you
Is it consist with the two graph that I send you ?
And I have a problem My graph says the work done is 0.26 J using trapz code.
I calculated the ΔKE=1/2mΔv2 Which gave me 0.42 J
and the real result using mgsinθx=W gave me 0.34 J
It means theoritaical value is 0.34 J , my experimental graph value is 0.26 J , experimental speed value is 0.42 J
There will be a friction and ΔKE-Wf=0.26J so 0.16 J gone to friction maybe ??
But there's also friction that we didnt reduce from experimental value which I thing that means I found the result with %10-15 error
Is that ok ?
