Given Two Point Charges, Find the charge at Point 0 as x,y
The problem involves two point charges located on the x-axis, with the goal of finding the electric field at the origin, point O. The charges are specified with their magnitudes and distances from the origin, and the task requires determining the x and y components of the electric field at that point.
  • Exploratory, Assumption checking
  • The original poster attempts to calculate the x component of the electric field using the relevant equation but expresses confusion regarding the y component. Some participants suggest that the electric field vectors from each charge point in specific directions and question the need for additional components.
The discussion is ongoing, with participants exploring the nature of electric field components and clarifying the original poster's understanding of how to approach the problem. There is acknowledgment of the original poster's concerns and a suggestion to consider the directionality of the electric field vectors.
The original poster indicates a desire for advisement and understanding, particularly regarding the y component of the electric field, which may not be directly applicable in this scenario.
vr0nvr0n
Two point charges are placed on the x axis. The first charge, q1 = 8.00 nC , is placed a distance 16.0 m from the origin along the positive x axis; the second charge, q2 = 6.00 nC , is placed a distance 9.00 m from the origin along the negative x axis.
Photo shown by problem:
http://imgur.com/mmQtBk0
Find the electric field at the origin, point O.
Give the x and y components of the electric field as an ordered pair. Express your answer in Newtons per coulomb to three significant figures. Keep in mind that an x component that points to the right is positive and a y component that points upward is positive.
Presumably, E=(q/r^2)k
What I can't seem to manage here is the Y component. I have used the relevant equation above and calculated the negative side and the positive side and subtracted the magnitude of the negative from the magnitude of the positive to find the X component at 0. But, I don't even see what I would use in the problem to find the charge along the Y component. I really want to understand this. Any advisement would be appreciated.
Sorry, I don't know why the photo isn't working. Here is the photo again:
components are "components", that is, parts of the whole. You don't have to go looking for hidden or separate y pieces. At the origin (or any other point in space for that matter) the electric field vector from each charge only points one direction. You seem to have correctly identified which way that is. Well then, how much of each electric field vector is along x and how much is along y? (0 is a perfectly good number)
Thank you.
There goes old vr0nvr0n, overthinking the problem again!
Thanks again.
