Discovering Global Extrema for f(x,y)=sin(x) + cos(y) on [0,2π]x[0,2π]
  • Thread starter Thread starter mathrocks
    Extrema Global
The discussion focuses on finding the absolute maximum and minimum of the function f(x,y) = sin(x) + cos(y) over the rectangle defined by 0 ≤ x ≤ 2π and 0 ≤ y ≤ 2π. The absolute maximum is 2, attained at the point (π/2, 0), while the absolute minimum is -2, which can be found at (π/2, π). The analysis involves checking critical points, evaluating the function along the perimeter of the rectangle, and considering the corners of the domain. The use of partial derivatives and the Hessian matrix is also discussed for determining the nature of the extrema.
  • Understanding of trigonometric functions, specifically sine and cosine.
  • Knowledge of partial derivatives and critical points.
  • Familiarity with evaluating functions over a defined domain.
  • Basic understanding of the Hessian matrix for classifying critical points.
  • Learn how to compute partial derivatives for multivariable functions.
  • Study the application of the Hessian matrix in determining the nature of critical points.
  • Explore methods for evaluating functions along the boundaries of a defined domain.
  • Investigate optimization techniques for functions of multiple variables.
Students and professionals in mathematics, particularly those studying calculus and optimization, as well as anyone interested in applying these concepts to real-world problems involving multivariable functions.
mathrocks
I'm supposed to find the absolute max and min for f(x,y)=sin(x) +cos(y) on the rectangle defined by 0<=x<=2*pi 0<=y<=2*pi. Can someone point me in the right direction. I got the critical points but i don't know what to do after that.
This can be solved with a few elementary facts concerning the sin and cos functions and no calculus at all.
First, disregarding the rectangle for a moment, it is obvious that f(x,y) must lie between -2 and 2 inclusive for any x and y, because both sin(x) and cos(y) lie between -1 and 1 inclusive, and f(x,y) is the sum of these two.
Second, it is easy to find a pair (x,y) in the rectangle where the values of -2 and 2 are actually attained. For instance if x = PI/2 and y = 0 then f(x,y) = 2. I leave -2 for you to do.
Since f(x,y) attains the values of -2 and 2 on the rectangle, and these values cannot be exceeded for any (x,y), they must be the absolute max and min.
How do I do this using calculus though, so I know what to do for other problems that arise. I know I must find the partial derviative for f(x,y) and find the critical values of each of those, which I believe are (pi/2, pi), (3*pi/2, 2*pi). Then I'm suppose to do something with the rectangle but I'm not sure what?
You need to check the value of f(x,y) along the perimeter of the rectangle.
Consider the fact that the maximum value of the function f(x) = x on the interval from 0 to 1 occurs at the point x = 1 where the maximum value is f(1) = 1. At that point, f'(x) = 1, not 0. So looking for points where f'(x) = 0, while necessary, is not sufficient. Loosely speaking, you need to examine the edges of the domain as well as the points where the derivative is zero.
Ok, I'm starting to understand this a little better now. Now my new question is when you have the domain be something like 0<=x<=2*pi, 0<=y<=2*pi, do you have to actually go through each value and see which combination gives you a maximum? Because in the case of f(x,y)=sin(x)+cos(y), the endpoints don't yield a maximum.
In general, yes. The reason is somewhat technical, and if you don't understand the rest of this paragraph, you can just accept the answer and safely skip on to the next one. Loosely speaking again, you cannot be assured that the 'edge' of the domain allows analysis. For instance, let the domain be the interior of the rectangle along with some points along the edge thrown in for good measure. Then finding the max of a function on that domain could require you to evaluate the function at those extra points on the edge one by one. Of course, if there were a lot of them, then you could be in it for the long haul. The good news is that the teacher would have the same amount of work to do in order to check your answer, so it probably won't happen to you while you are in school.
However in particular cases you may be able to do better. In fact, for the case at hand, you can look for the extrema along each of the 4 edges by looking for points where the partials are 0 and then evaluate the function at each of the 4 corners.
That's the thing, when I look for the points where the partials are 0, I get
(x=pi/2), (x=3*pi/2) and (y=pi), (y=2*pi). And when I evaluate the function at the corners which are (x=0), (x=2*pi), (y=0), (y=2*pi), I get x=0, x=0, y=1, y=1. So I don't see how I can get -2,2 even though I know I should.
So you need to look at the following points:
1. The points in the interior of the rectangle where the partials are 0.
2. The points along the sides where the partials are 0.
3. The corners.
The largest value of f(x,y) among the union of these three sets of points is the absolute maximum. Similarly for the minimum value.
f(x)=:\sin x+\cos y
The condition for extremum-------->critical points.
\frac{\partial f}{\partial x} =0 ;\frac{\partial f}{\partial y}= 0
The type of extremum---------->
Hess(f)|_{sol.critical points} ? 0
Daniel.
P.S.If the hessian is the positive,then it's a minimum,if it's negative,it's a maximum,if it's zero,it's a saddle point...
