Globe Earth question: Percent of the Earth receiving sunlight at a given time
  • Thread starter Thread starter Thomas456
    Sunlight
The discussion revolves around the alignment of the daylight region on a 3D model of the Earth with the theoretical 50% of the Earth's surface that receives sunlight at any given time. Participants explore the implications of different viewpoints and the effects of perspective on visibility, as well as the definitions of twilight and daylight in relation to population statistics.
  • Some participants express confusion about why the 50% daylight region does not align with the visible parts of a 3D Earth model, despite attempts to match them.
  • Others note that the viewpoint in the 3D model is likely too close to the Earth, which would limit the visible area to less than 50% of the surface.
  • One participant suggests that achieving a 50% view would require a viewpoint effectively at infinity, where rays from the Sun would be parallel.
  • Another participant questions the necessity of an infinite viewpoint, arguing that the Sun is not at infinity and still illuminates 50% of the Earth.
  • Some participants discuss the mathematical implications of the viewpoint distance needed to achieve a 50% view, suggesting that a compromise distance would yield a view slightly less than 50%.
  • There are mentions of the angular diameter of the Sun affecting the perceived illumination of the Earth.
  • One participant suggests that an orthographic projection of the Earth might be more suitable than a 3D model for this purpose.
Participants generally do not reach a consensus on the necessity of an infinite viewpoint or the exact percentage of the Earth's surface visible in the 3D model. Multiple competing views remain regarding the alignment of daylight regions and the implications of perspective.
Limitations include the dependence on the definitions of daylight and twilight, the effects of perspective on visibility, and unresolved mathematical calculations regarding the distance required for a 50% view.
Thomas456
I recently stumbled on a problem I can't solve.
For background, there is a recent story from July 8 about 99% of people receiving sunlight at 11:15 am. Anyone can google it and it's explained fairly well at time and date. There is an illustration. Here: https://www.timeanddate.com/news/astronomy/99-percent-sunlight-july-8
is a region of daylight that accounts for 50% of the globe, with other bands indicating various types of twilight. This daylight region should align nicely with a 3D view of the Earth. Link here: https://www.echalk.co.uk/Science/physics/solarSystem/InteractiveEarth/interactiveEarth.html
Problem is it does not. Try as I might, I cannot get the 50% daylight region to align with the visible parts of 3D Earth. Why?
:welcome:
I'm sure this question was asked some time ago.
I like the fact checking in the first link:
Claim Confirmed, But…
So, the claim is technically true if you count all twilight areas, no matter how dimly lit.
But the percentage of the population actually perceiving sunlight is a bit lower. Discounting all of the people in the astronomical twilight zone and half of the population experiencing nautical twilight, we get 7204.9 million people, or about 93% of the world’s population.
It’s still a very high number. But the wording of the more recent versions of the post, claiming that 99% of the population will “experience daylight,” is somewhat misleading.
Yes, I read it. Its not my question. My question is why the 50% of the daylight region does not align with what is visible on a 3D Globe. I have tried for hours, and it doesn't fit the parameters. If you can do it, all it takes is a screenshot to show it.
Yes, its a good article. To be clear, Im not confused about the twilight region. I specified the daylight region. Try to line up the visible daylight region from the first link, with a global 3D map. It just doesn't align.
Hopefully, this illustrates the problem. Here is a screengrab from 3D earth. This is one of my attempts to get alignment Notice how it does not align with the 50% daylight region? There are many discrepancies:
It should extend nearly to Antarctica.
It should include more of South America
It should include South East Asia
It should include most of North America.
It does not.
Move the 3Dglobal model about, and the problems multiply. Try it yourself. Why doesn't the visible region align with the Daylight region? Explanation requested. Or if you can get the 3D model to fit the very identifiable parameters of the Daylight regions as illustrated in the link, post a screenshot.
I think the viewpoint in your 3D global view is not at infinity, it is relatively close to the Earth. So it is not showing 50% of the Earth, but less than 50%. As you get closer and closer to the Earth, you see less and less of the area.
Hmmm, thats interesting. I have looked at several 3D models with the same result. Do you have one where it does show 50%? Seems to me that would be a pretty basic standard. And how would it need to be at infinity? The Sun is not at infinity. Thanks for your reply.
You do raise an good point though. Follow up question. What would be the distance that a 50% view of the Earth would be achieved? Math equation?
1. When you look at the Earth from closer than the Sun, you do not see a full hemisphere because your horizon is closer. The area you see approaches zero, as your height approaches zero.
2. The 99% of population, comes I think from the definitions of the different twilights, when the upper limb of the Sun is 6°, 12°, or 18° below the horizon for astronomical twilight.
You can get to see it backwards from the antipodes, at night, when the two 18° effects of twilight and observer height can cancel. I have not calculated the exact observer height for an 18° encroachment of the horizons, but the cancellation effect is visible.
Use the link:
Select population density.
Then look at the Pacific Ocean, from above the Tropic of Capricorn, (23.5°S), and minimise the population visible. Make sure you cannot see the population of Japan.
At that time, those people you cannot see have sunlight or twilight.
1. Thats my question! So you are saying the 3D Globe is not going to show 50%. Any idea how much it does show? Isn't there a math formula for the distance needed to show 50% from the diameter? Btw, my Globe link is the same as yours only selected for terrain.
2. I have zero confusion over twilight vs daylight. I am going by the DAYLIGHT parameters of the link. I have zero questions about population density vs visible sunlight.
Not unless the viewpoint is effectively at infinity, no.
Or a diagram (presumably) has no distortion, like this:
Not without knowing the distance from the POV, no.
Yes. 50% of the Earth will be visible when the rays from opposite limbs (i.e. diametrically opposed points) are parallel, which only happens at effectively infinity.
What you want is a compromise. Something far shorter than infinity will give you a view of Earth that is fractionally less than 50%.whats your comfort level? 49.9%? 49%? 45%?
Thanks someone else mentioned infinity. I don't understand this. The Sun is not at infinity, and illuminates 50% of the Earth. So how can we not see this?
It is effectively at infinity..
The rays from the sun hit the north pole and south pole effectively in parallel.
Problem is, from the Sun,the Earth is too tiny to see. You can only see detail when close by.
Because the Sun has an angular diameter of about 0.5°, it has an angular radius of 0.25° which pulls the 180° of the illuminated sphere back to 179.5°, which does not require the Sun to be at infinity.
Yes, the OP doesnt really need infinity.
What they need is a orthographic projection of Earth, not one in 3D.
Plenty of static maps like like but not sure if renderers of that type are very common.
Way over my head, but interesting! Thanks. It does answer my question on why I could not make the map align with the model. I was really perplexed.
And one more thing, could you give a rough estimate looking at the link of the 3D map, of how much % you think is showing? Just so I have an idea.
Maybe I missed something about how that 3d globe link works, but can you pick the day? The timeanddate link says it was July 8.
Thanks someone seems to have answered my question. The 3D globe is in the link. The other link is to an article, which is July 8. I cannot pick the day on the globe. I was trying to see if I could align it to roughly the solstice.
I saw the link to the 3D globe model. What I'm asking is if you can set the date. I'm not seeing such controls on it. The 99% thing only happens at a specific time and date. Also...if you're using the projection as if you are the sun, that would mean you need to tilt earth's axis towards you.
I don't have any questions about the 99% claim. The article explained it really well.
I cannot set the date on the 3D model.
What is left for you to accomplish?
In light of what you now know, can you restate your goal?
Direct observation cannot show all the people 18.25° over the horizon. But reversing the process, looking for less than 1% of the population, at the solstice, puts the observer over the Pacific Ocean, the southern tropic of Capricorn.
I believe I said you answered my question. I was hoping for a rough estimate on how much the 3D model does show , but I can see physics guys don't deal in rough estimates.
Many thanks for everyone here.
Have a great night. My goal now is to enjoy the rest of the night.
Thanks for your input. Have a great night.
I'm aware and aware the OP's main question has been answered. I'm just saying I'm not even sure if OP was using his globe simulation correctly.
I did tilt the axis every which way, but It didn't make a difference. The answer seems to be that the 3D model doesn't show 50%, so it wouldn't matter. But it was still helpful to learn from you it should be pointed toward me to approximate solstise rather then may admittedly crude method of looking from the Northern Hemisphere. Thanks.
Have a great night.
Have a great night.
Ahh - you can click and drag it manually. Fair enough.
And I did a lot of clicking and dragging!
I see what you did there... :wink:
