High School GMm/r^2 for r=0? Force at Center of Object?
  • Thread starter Thread starter JLT
In a scenario where a hollow Sun has another mass at its center, the gravitational force calculated using the formula GMm/r^2 would approach infinity due to the zero distance between the centers. However, this expression does not accurately describe the force between the two masses. According to the Shell Theorem, the gravitational force at the center of a hollow spherical mass is actually zero, as the forces from different parts of the mass cancel each other out. This highlights the importance of understanding gravitational interactions in spherically symmetric mass distributions. Thus, while the mathematical expression suggests infinity, the physical reality indicates no force acting between the masses.
JLT
This is probably a stupid question - but let's say you have a hollow Sun (M is hollow), with another mass in the center, so M and m share the same center of mass, the distance between the centers is zero.
Would GMm/r^2 be infinite in this case?
The force at the center of any object - if you define your system to be the center chunk of matter, and how that center chunk of matter sees the rest of the planet?
((o))
sorry... I did not get enough sleep last night, that's my excuse!
The 1/r^2 expression is only valid for the gravitational force on an object outside a spherically symmetric mass distribution.
Your expression would go to infinity, but it would not be describing the force between the objects.
Likes JLT
The force is, in fact, zero. Look up the Shell Theorem.
Larry Niven wrote a novel called Ringworld which featured a ring around a star. He had to write a followup describing the giant ion engines the ring had to keep itself centred on its star because this fact was brought to his attention after publication...
Likes JLT
((o))
actually their will be no force acting because all the forces from different part of the sun will cancel out.
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 67 ·
  • · Replies 25 ·
