Does Shaft Flex Affect Distance in Golf Swings?
  • Context: Undergrad
  • Thread starter Thread starter fdb2
    Golf Physics Swing
The discussion centers on the impact of shaft flex in golf clubs on the distance a golf ball travels when struck. Participants explore the physics involved in the swinging of the club and the energy transfer during impact, considering various factors such as swing speed and shaft characteristics. The conversation is primarily theoretical and conceptual in nature.
  • One participant suggests that increasing shaft flex may influence distance, noting that different flexes exist and that too much flexibility can reduce accuracy.
  • Another participant proposes that energy transfer at the moment of contact affects distance, arguing that a more flexible shaft could allow the ball to travel further by directing more energy to it, while a stiffer shaft might limit the clubhead's movement and thus affect the ball's distance.
  • A third participant states that shaft flex is related to swing speed, emphasizing the importance of having the shaft straight at the moment of impact to maximize energy transfer and accuracy.
  • This participant also mentions that the stiffness of the shaft should match the swing speed to ensure optimal performance, implying a relationship between shaft characteristics and player dynamics.
Participants express differing views on the relationship between shaft flex and distance. While some suggest that increased flexibility could enhance distance, others emphasize the importance of accuracy and the need for the shaft to be straight at impact. The discussion remains unresolved with multiple competing perspectives.
Participants do not reach a consensus on the effects of shaft flex on distance, and assumptions regarding swing mechanics and energy transfer are not fully explored or agreed upon.
fdb2
I hope this comes under the classic physics roof. Do any of you play the game and would like to offer your opinions on the physics of the club swinging into and propelling the ball toward the target?
If any would like to take on a problem of shaft flex I would enjoy hearing about your views. Here goes: As a good player swings the club the golf shaft flexes. All shafts ( steel or graphite) have different flexes ranging from extra-stiff ( think telephone pole) to ladies flex. ( think fly rod ). Now the problem is this: Will increasing flex ( bending) on the downswing increase the players distance. I know for a fact ( empirical here) that a too flexible shaft decrease accuracy, however I would like to hear thoughts on distance only versus flexibility. Some parameters if you like, Head mass is 200 grams and shaft length is 44 inches. Let's not get into materials. Shaft weight is a compromise between steel and graphite and for argument sake let's say shaft mass is 85 grams.
Your commentary is appreciated.
Regards, FDB
Just off the top of my head, I would have to say that shaft flexibility must effect distance. At the moment of contact, energy is transferred from the clubhead to the ball. At that instant, two things happen; the ball accelerates foreword and the clubhead accelerates backward (decelerates). There is only a certain amount of energy generated by the impact between these two. Whatever portion of that energy is expended in accelerating the clubhead backward is energy not available to accelerate the ball forward.
This energy transfer could be pictured in the form of an "explosion" of energy between the ball and the clubhead. If you imagine placing a golf ball and the head of the golf club next to each other with a small explosive charge (perhaps a firecracker) between them, you can see that when the explosive detonates the energy from that detonation will push on both objects. If the clubhead is not attached to anything, both objects are equally free to move. Both will travel equal distances (d) in opposite directions from the point of the explosion (if we use a clubhead that's the same mass as a golfball). If the clubhead is attached to a very flexible shaft and the other end of that shaft is held stationary, then the clubhead might only travel 1/2 as far, (.5d) in which case the ball should travel twice as far (2d). Given a more rigid shaft, the clubhead could be restricted to traveling only 1/10 that distance (.1d), directing the remainder of the available energy to propel the ball nine times as far (9d).
These differences are, of course, greatly exaggerated. However, the principal which they illustrate remains sound.
Thanks, anyone else have thoughts?
Shaft flex is directly related to swing speed. The idea is that the shaft should be perfectly straight when you strike the ball (otherwise you get the inaccuracy you were talking about, plus you don't recover all of the energy from the flex). When you are accelerating the clubhead, it lags behind, bending the shaft. When you get to the contact point, it bends back, adding energy to the shot. The faster your swing, the stiffer the shaft has to be to "rebound" in time to be straight at the contact point. A stiffer shaft has a higher natural frequency than a more flexible one, and you essentially tune the frequency to your swing speed.
14K
  • · Replies 21 ·
