Grad of a Scalar Field: Computing ∇T in Spherical Coordinates
The discussion revolves around computing the gradient of a scalar field T(r) in spherical coordinates. Participants are tasked with demonstrating the expression for ∇T and exploring the implications of the gradient operator in this coordinate system.
  • Participants discuss the computation of T(r+dl)−T(r) using two different methods and compare results. There is an exploration of the components of the gradient and their relationship to the infinitesimal displacement vector in spherical coordinates.
The discussion is ongoing, with participants sharing their attempts and questioning their understanding of the gradient operator. Some guidance has been provided regarding the relationship between the components of the gradient and the infinitesimal displacement, but there is no explicit consensus on the final interpretation of the results.
Some participants express uncertainty about the correctness of their previous work and the definitions being used, indicating a need for clarification on the mathematical concepts involved.
ConorDMK
Let T(r) be a scalar field. Show that, in spherical coordinates T = (∂T/∂r) rˆ + (1/r)(∂T/∂θ) θˆ + (1/(r*sin(θ)))(∂T/∂φ) φˆ
Hint. Compute T(r+dl)−T(r) = T(r+dr, θ+dθ, φ+dφ)−T(r, θ, φ) in two different ways for the infinitesimal displacement dl = dr rˆ + rdθ θˆ + r*sin(θ)dφ φˆ and compare the two results.
= (∂/∂x)xˆ + (∂/∂y)yˆ + (∂/∂z)zˆ
dT(r) ≡ T(r+dl)-T(r) = T(r+dr, θ+dθ, φ+dφ) - T(r,θ,φ) = (T(r,θ,φ) + (∂T(r)/∂r)dr + (∂T(r)/∂θ)dθ + (∂T(r)/∂φ)dφ) - T(r,θ,φ)
⇒ dT(r) = (∂T(r)/∂r)dr + (∂T(r)/∂θ)dθ + (∂T(r)/∂φ)dφ
But I don't know where I can go from here, and I don't think what I've done previously is correct (I rubbed out some of the work that continued form this, as I don't know what I can and can't use.)
I think they are defining the gradient [itex]\nabla T[/itex] to be a vector such that [itex](\nabla T) \cdot \vec{dl} = dT[/itex]. You already have computed [itex]dT[/itex]; it's just [itex]\frac{\partial T}{\partial r} dr + \frac{\partial T}{\partial \theta} d\theta + \frac{\partial T}{\partial \phi} d\phi[/itex]. So you have the equation:
[itex](\nabla T) \cdot \vec{dl} = \frac{\partial T}{\partial r} dr + \frac{\partial T}{\partial \theta} d\theta + \frac{\partial T}{\partial \phi} d\phi[/itex]
The left-hand side of that equation can be written as: [itex](\nabla T)_r (dl)_r + (\nabla T)_\theta (dl)_\theta +(\nabla T)_\phi (dl)_\phi[/itex], where [itex](\nabla T)_r[/itex] means the r-component of [itex]\nabla T[/itex], etc. and [itex](dl)_r[/itex] means the r-component of [itex]dl[/itex], etc.
So just expand [itex](\nabla T) \cdot \vec{dl}[/itex] in terms of components of [itex]\nabla T[/itex] and [itex]\vec{dl}[/itex], and see what you get.
What is the equation for ##\vec{dl}## in spherical coordinates (I.e., using the spherical coordinate unit vectors)?
(T)r(dl)r = (∂T/∂r)(dr/dr)rˆ = (∂T/∂r)rˆ
(T)θ(dl)θ = (∂T/∂r)(dθ/dθ)θˆ = (∂T/∂θ)(1/r)θˆ
(T)φ(dl)φ = (∂T/∂φ)(dφ/dφ)φˆ = (∂T/∂φ)(1/(r*sin(θ)))φˆ
T(r) = (T)r(dl)r + (T)θ(dl)θ + (T)φ(dl)φ = (∂T/∂r)rˆ + (∂T/∂θ)(1/r)θˆ + (∂T/∂φ)(1/(r*sin(θ)))φˆ
This is what I had before, but I didn't think this was right.
And I also, apparently, have to do it with another method.
No, there is no [itex]\hat{r}[/itex]. When you take a dot-product, you just get a number:
[itex](\nabla T)_r (dl)_r = \frac{\partial T}{\partial r} dr[/itex]
So, you didn't actually take my hint. Let me spell it out for you more explicitly:
One way of calculating [itex](\nabla T) \cdot \vec{dl}[/itex]:
[itex](\nabla T) \cdot \vec{dl} = (\nabla T)_r (dl)_r + (\nabla T)_\theta (dl)_\theta + (\nabla T)_\phi (dl)_\phi[/itex]
We have: [itex](dl)_r = dr[/itex], [itex](dl)_\theta = r d\theta[/itex], [itex](dl)_\phi = r sin(\theta) d\phi[/itex]. So we have:
[itex](\nabla T) \cdot \vec{dl} = (\nabla T)_r dr + (\nabla T)_\theta r d\theta + (\nabla T)_\phi r sin(\theta) d\phi[/itex]
Second way of calculating [itex](\nabla T) \cdot \vec{dl}[/itex]:
[itex](\nabla T) \cdot \vec{dl} = dT = \frac{\partial T}{\partial r} dr + \frac{\partial T}{\partial \theta} d\theta + \frac{\partial T}{\partial \phi} d\phi[/itex]
So putting those two together gives you:
[itex](\nabla T)_r dr + (\nabla T)_\theta r d\theta + (\nabla T)_\phi r sin(\theta) d\phi = \frac{\partial T}{\partial r} dr + \frac{\partial T}{\partial \theta} d\theta + \frac{\partial T}{\partial \phi} d\phi[/itex]
So, what do you think [itex](\nabla T)_r[/itex] must be? What is [itex](\nabla T)_\theta[/itex]? What is [itex](\nabla T)_\phi[/itex]?
Sorry, I kept thinking ∇ had to be a vector.
(∇T)r = (∂T/∂r)
(∇T)θ = (∂T/∂θ)(1/r)
(∇T)φ = (∂T/∂φ)(1/(r*sin(θ)))
(∇T)r = (∂T/∂r)
Your answer is correct. But your implication that del is not a vector is not quite correct. Del is a vector operator.
(∇T)r = (∂T/∂r)
It is a vector (in the way you're being taught--it actually should be a covector, but that's kind of an advanced topic). A vector has three components.
