Undergrad Gradient Vectors: Perpendicular to Level Curves
  • Thread starter Thread starter AAMAIK
    Gradient Vectors
The gradient vector transforms a scalar function into a vector function, representing the rates of change with respect to independent variables and is always perpendicular to level curves, indicating the direction of increasing function values. When approximating a function near a point, the tangent plane must align with the gradient vector's slopes in the respective directions. The discussion highlights the importance of understanding the relationship between the gradient and level curves, emphasizing that the gradient's direction indicates where the function increases most rapidly. Additionally, it clarifies that the gradient is specific to the dimensionality of the space being analyzed, such as 2D or 3D. Overall, the gradient vector is crucial for analyzing changes in multivariable functions.
AAMAIK
TL;DR
Gradient vector definition and its properties how its interpreted and what is it good for?
The gradient transforms a scalar function into a vector function where the vector components are the rates of change of the functions with respect to its independent variables.
Also, the properties of the gradient are:
It lies in the plane.
It is perpendicular to the level curves and points towards higher values of the function.
(1)
I am not sure of my interpretation of the definition, but that is how I understood it
Consider a function of two independent variables x and y. If I want to approximate the function in the neighbourhood of the point (x0,y0), then the tangent plane must pass through the same point (x0,y0) and to narrow down the many candidates of the different tangent planes the tangent plane must have the same slopes as the surface in the i and j directions (this is captured by the gradient vector).
The link describes the proof the grad vector is perpendicular to the level curves
https://ocw.mit.edu/courses/mathematics/18-02sc-multivariable-calculus-fall-2010/2.-partial-derivatives/part-b-chain-rule-gradient-and-directional-derivatives/session-36-proof/MIT18_02SC_notes_19.pdf
I don't understand why we take any arbitrary curve r(t) on the level curve surface and the chain rule to prove the property. If my understanding is correct in (1) then I could shown that the gradient is perpendicular to level curves as follows. The tangent plane approximating the function at (x0,y0) will intersect the level surface f(x0,y0)=c in a line that lies on the level surface and if the value of the function does not changes implies that the gradient vector is perpendicular to the change to the position vector along that line of intersection.
In general, this is not true. For example, a tangent plane to a sphere only intersects the sphere once.
AAMAIK said:
Summary:: Gradient vector definition and its properties how its interpreted and what is it good for?
What plane? The gradient is a vector with the same number of components as your underlying space. If you work in ##\mathbb R^3##, then the gradient will be a vector in 3D and may point in any direction.
If we are considering a function of two variables then what I meant was the horizontal plane and not the trace on that horizontal plane.
There is such a thing as a gradient vector field. Let's assume we have a function f(x,y) defined on the plane. Then if (x0, y0) is a point, consider any unit vector u = (a,b). Then a line leaving the point (x0, y0) in the direction u is given by L(t) = (x0, y0) + t(a,b).
Now consider the values of f(x,y) along that line, or in other words f(L(t)) = f((x0 + ta, y0 + tb). Let's see how fast that function of t is increasing: using the chain rule we get d/dt (f(L(t)) = ∂f/∂x * a + ∂f/∂y * b. Or in other words, the dot product of (∂f/∂x, ∂f/∂y) and u. (Where the partial derivatives are to be evaluated at the point (x0, y0).) And of course (∂f/∂x, ∂f/∂y) is by definition the gradient of f at (x0, y0). So the directional derivative of f in the direction of u is just the dot product of the gradient with u.
From this it's easy to see that at (x0, y0), the function f(x,y) increases fastest in the same direction as (∂f/∂x, ∂f/∂y) (this is a good exercise).
Likes jim mcnamara
12K
12K
