Graphical Analysis of Functions: Finding g(x+3) at x=1
The discussion focuses on evaluating the function g(x) = (x - 4) / (2x) and its transformations. The participants clarify that for g(x + 3) at x = 1, one must first compute x + 3, resulting in g(4). The confusion arises from interpreting the notation, but it is established that the correct approach is to evaluate g at the transformed input rather than shifting the graph. The initial substitution and simplification of g(1/x) are confirmed as correct.
  • Understanding of function notation and evaluation
  • Familiarity with algebraic manipulation of rational functions
  • Knowledge of graph transformations and shifts
  • Basic comprehension of the concept of domain in functions
  • Study the properties of rational functions and their graphs
  • Learn about function transformations, including shifts and reflections
  • Explore the concept of function composition and its applications
  • Practice evaluating functions with different inputs and transformations
Students studying algebra, mathematics educators, and anyone looking to improve their understanding of function evaluation and transformations.
sportsguy3675
Little help please and some work checking.
Given f(x)=3x+2 and g(x)=\frac{x-4}{2x}
It asks for g(\frac{1}{x})
So substitute in: \frac{\frac{1}{x} - 4}{2(\frac{1}{x})}
Simplify: \frac{\frac{1}{x} - 4}{\frac{2}{x}}
I multiply top and bottom by x right?
That would give: \frac{1 - 4x}{2} and D_{f} = \Re Correct?
Then on this other problem I have a graph of different functions f and g. The problem says g(x+3) at x=1. Does that mean I find the y value on g where x = 1 (4) and then add 3 and then find g(7)? Or do I add 1 to 3 and take g(4)?
listen up sportsguy...
ur first working is correct...
for the second one...do u have only the graph or is the equatios provided?
its pretty simple for the second one too where in case u were jus given the graphs...
g(x+3) means notin but shifting the graph by 3 units to the left...if u could redraw the graph then...just draw it and look for the value at one...or the more simpler approach would be to jus look for the value at g(4)...
OK, thanks.
On the 2nd part, it has nothing to do with graphing. There is just a graph with f and g drawn on it and you just have to find the value based on that graph. All the other questions were normal but I don't understand the whole at x = whatever business. That why I asked if it was asking for g(4) or g(7).
The second problem says f(x+3)- that is x+ 3, not y+ 3! Also, that "x+3" is inside the parentheses for the function.
If x= 1 then you add x not y: x+ 3= 1+ 3= 4. Then apply the function.
If x= 1, f(x+3)= f(1+ 3)= f(4).
Yeah, but see it didn't say If, it said at. But I did look on the graph for f(4). :)
  • · Replies 21 ·
  • · Replies 16 ·
