Graphing Ellipses: How to Change Formats
The discussion revolves around the process of graphing an ellipse given in a specific equation format. Participants explore the implications of the coefficients in the equation and how to manipulate it into a standard form suitable for graphing.
  • Homework-related
  • One participant questions how to graph the ellipse given by the equation \((x+2)^2 /5 + 2 (y-1)^2 = 1\) and expresses confusion about the coefficient of 2 in front of \((y-1)^2
  • Another participant confirms that the standard form of an ellipse is \(\frac{x^2}{a^2} + \frac{y^2}{b^2} = 1\) and explains how to adjust the equation for an ellipse centered at a point other than the origin.
  • A participant expresses uncertainty about whether the coefficient of 2 could be a typographical error, suggesting it might mean \((y-1)^2/2\) instead of \(2(y-1)^2\).
  • Another participant responds by explaining how to rearrange the equation to \(\frac{(x+2)^2}{5} + \frac{(y-1)^2}{\frac{1}{2}} = 1\), indicating that this clarifies the situation.
Participants generally agree on the standard form of the ellipse and how to manipulate the equation, but there is uncertainty regarding the interpretation of the coefficient of 2 in the original equation, with one participant suggesting it might be a mistake.
The discussion does not resolve the uncertainty about the coefficient of 2, leaving open the possibility of it being a typographical error.
veronica1999
How do I graph this ellipse?
It doesn't seem to be in the right form.
I don't know what to do with the 2 in front of the (y-1)^2
Doesn't an ellipse have to be x^2/a^2 + y^2/b^2 = 1
Mathematics news on Phys.org
Hi veronica1999, :)
Yes, an ellipse has its equation as, \(\displaystyle\frac{x^2}{a^2} + \frac{y^2}{b^2} = 1\) if its major and minor axes coincides with the \(x\) and \(y\) axes of the Cartesian coordinate system. In this case the center point of the ellipse is at the origin. However a ellipse with its center point at, \((x_{0},y_{0})\) has an equation of the form,
\[\frac{(x-x_{0})^2}{a^2} + \frac{(y-y_{0})^2}{b^2} = 1\]
In your case the ellipse is centered at, \((-2,1)\). Now you should be able to draw your ellipse. :)
Kind Regards,
Sudharaka.
Thanks.
But I am still not sure what to do with the 2 in front of the (y-1)^2.
Could it have been a mistype meaning (y-1)^2/2 instead of 2(y-1)^2?
veronica1999 said:
Thanks.
Of course not. You can rearrange the equation by taking that \(2\) to the denominator like this,
\[\frac{(x+2)^2}{5} + \frac{(y-1)^2}{\frac{1}{2}} = 1\]
Is it clear to you now? :)
Yes!;)
Thank you!
veronica1999 said:
Yes!;)
Thank you!
You are welcome. I am glad to be of any help. :)
