How to Graph the Inverse of a Function on a TI-84PlusCE?
  • Thread starter Thread starter Witcher
    Graphing
This discussion provides a step-by-step guide on how to graph the inverse of a function using the TI-84 Plus CE calculator, specifically for the equation Y^3 = X. The method involves using the "DrawInv" function, which can be accessed through the "DRAW" menu or by directly entering "DrawInv Y1" on the main screen. Users must ensure that the original function Y1 = X^3 is activated in the list of functions to visualize the inverse correctly. The process is confirmed to work effectively for users seeking to graph inverse functions on this calculator model.
  • Understanding of inverse functions and their graphical representation
  • Familiarity with the TI-84 Plus CE calculator interface
  • Basic knowledge of function notation and graphing
  • Ability to navigate the calculator's DRAW and VARS menus
  • Research how to graph other types of inverse functions on the TI-84 Plus CE
  • Learn about the implications of graphing cubic functions and their inverses
  • Explore additional graphing features of the TI-84 Plus CE, such as parametric equations
  • Study the mathematical properties of cubic functions and their inverses
Students, educators, and anyone using the TI-84 Plus CE calculator for graphing functions and exploring inverse relationships in mathematics.
Witcher
I just need help figuring out how to graph an equation on my calculator.
The hard part is getting y cubed
Y^3=x
What goes here?
Witcher said:
Homework Statement:: I just need help figuring out how to graph an equation on my calculator.
Homework Equations:: Y^3=x
What goes here?
Take the cube root of both sides of the equation.
Alternative to @Mark44 's fine suggestion:
You could use the "DrawInv" function.
To do this, suppose you have Y1=X^3 as a function to be graphed.
Go to the main screen.
To graph the in verse of Y1, you will need to have your display screen show: "DrawInv Y1".
If you know how to do this, fine. Press "ENTER".
Else:
Go to the "DRAW" menu: (2nd - PRGM) and pick item 8, which is DrawInv .​
Next: Look under "VARS", you need the ""Y-VARS" option. The first option under that is "Function ... ", which you should choose, then click on "Y1". (or whatever YN is relevant)​
The main screen should show:​
DrawInv Y1
Press "ENTER".​
This will give the graph of X = Y3.
It may also show the graph of Y = X3, depending upon whether or not Y1=X^3 is activated in the list of functions to be graphed.
Likes Witcher
Else:
DrawInv Y1
Press "ENTER".​
Thank you so much! This worked! Mind if i pm you?
