Grass Death Under Power Lines: EMF's a Factor?
The discussion revolves around the observation of dead plants under power lines and whether electromagnetic fields (EMFs) from these lines could be a contributing factor. Participants explore various hypotheses, including the potential use of herbicides by power companies and the effects of EMF on plant health.
  • Some participants suggest that the death of plants under power lines may be due to herbicide application by the power company to maintain clear right-of-ways.
  • Others question the longevity and effectiveness of herbicides in the presence of sunlight and weather conditions, noting that no vegetation has regrown in the area for at least eight years.
  • A participant mentions the possibility of plants bending away from transmitting antennas, raising questions about the effects of EMF on plant growth.
  • One participant shares a graph of EMF measurements based on distance from power lines, but others express confusion about the units and the relevance of the data.
  • Concerns are raised about the potential health effects of living near power lines, with some suggesting that there may be a correlation between power lines and health issues, although this remains speculative.
Participants do not reach a consensus; multiple competing views exist regarding the causes of plant death under power lines, including herbicide use and the effects of EMF. The discussion remains unresolved with ongoing questions about the relationship between power lines and vegetation health.
Participants note limitations in their observations, such as the lack of clear data on the type of power lines and the absence of scale units in the shared graph. There are also unresolved questions about the impact of environmental factors on herbicide effectiveness.
This discussion may be of interest to individuals studying environmental science, plant biology, or those concerned with the effects of electromagnetic fields on health and vegetation.
FlimFlam
So I was messing with the induction from power lines and fluorescent bulbs, and I noticed all the plants under the power lines were dead but plants around it were fine. Do EMF's have something to do with this?
No. More likely the power company applied a herbicide to keep the area clear of vegetation. Otherwise, why would there even be dead plants there?
I would suspect herbicide application. One wants to be able to get into the power line right-of-way and might be discouraging vegetation. [And might have chosen the wrong herbicide]
How long would that work though? Power company hasn't been trough this area in at least 8 years and still nothing appears to grow.
But how long would the herbicide be useful for out in the sunlight and with weather? Power company or really any company haven't passed trough this area in at least 8 years and there's still nothing growing.
Can you post a picture? It could be that the plants around the right-of-way don't do a lot of regeneration...
And keep in mind that the power company may not like the idea of you tapping into their power distribution grid (even just through inductive coupling). They like to charge for that power, after all... :smile:
http://152.87.4.98/power/rightofway/images/anatomy-1_DSC9583.jpg
Ill get some pictures when I arrive home. I am not leeching power,just pointed a CFL bulb at the power lines. I could post the magnetic field data I took if you're interested.
They inspect it more often and decide when to do something based on how big the plants grow.
Tree branches falling on power lines cause more outages than any other cause other than squirrels.
You said there are plants there, but they are dead. Based on the size of the dead plants you might be able to speculate on frequency or longevity of application.
I suspect the power company is responsible for keeping ther area clear and doesn't want to be mowing once a month.
A road near me installed wire guard rails on the median a few years ago and immediately after installation, the grass underneath died. Makes it easier to mow the median.
well half of the vegetation is like a foot high but bent over and he other half is dead grass about an inch high
FYI, Google has a lot to say about "herbicide under power lines"...
Here's the road I was referring to. You can see there is a narrow strip of deadness under the guard wire, but also that they still didn't mow close enough to it:
https://binged.it/2EwgkS0
On a local 'power pole' scale rather than 'regional grid', you may get a different mix of plants and growth along 'trace' if the wires are popular perches for birds...
A gray squirrel (RIP) draped itself between case and high tension bushing a while back, and took out my "pole pig" distribution transformer primary fuse. The lineman added a "squirrel insulator" during fuse replacement to prevent a repeat, and while I don't know what the distribution voltage is (suspect 7200V; it's on an old stretch in a rural area) your observation has me wondering ... are they ever implicated in taking out higher voltage distributions (69 kV, 225 kV, 345 kV, etc), or do the squirrels clear before protective relaying kicks in?
The median?? Mow the median? ,
Like in the song?
I have noticed plants bending away from transmitting antennas.
How dare they bend that way.
(Just kidding) :smile:
Made a graph of EMF based on distance from power lines.
We're they south of the power lines? Bent with the wind?
FlimFlam said:
Made a graph of EMF based on distance from power lines. View attachment 220420
I can't read the units on your graph.
Sounds fun. With a search you might find published data on power lines to compare with yours.
Just noticed excel messed up the units. Ignore Y axis, Z axis is displacement from the power-line in feet, X axis is magnetism measured in MicroTesla.
I can see no scale units on that graph so it means nothing to me, I'm afraid. Are these lines High voltage or for domestic distribution?
There are Power Lines all over the country and I have never noticed strips of different colour / density on fields used for either crops or animal grazing.
For decades, there have been claims that power lines have an effect on the health of people living near or below them. (Spend a few minutes on Google Earth)
Of course, it is not in the interest of Power companies to accept there is a case against them so there is always the possibility that the 'facts' have been suppressed. Personally, I would believe that there may be some correlation between power lines and health - but there is also a strong negative correlation between routing of power lines and the income (aka influence) of people near them. Overall, that could imply a causal relationship between income and health but nothing else.
Sorry not the best at making graphs as you can see. Speaking of, I actually wanted to go to all the houses next to the power lines and and the residents questions about their health based on how many years they have lived there.
Is this for a school project or something?
Nope, personal interest
Sent from my SM-G900P using Tapatalk
I would suggest you check with local law enforcement and learn your legal rights before undertaking that project :wink:
What legal trouble could there be? Everything would be optional.
This disturbs me, but before I get into that, have you done any research on this? There is a lot of information out there...both good and bad...
Yes that's why I'm interested in asking long term residents about health effects
Some communities like the one I live in have ordinances in place that restrict door to door solicitation, so just be careful.
As for your topic, I have had a commercial property for more than 30 years that has six (144,000 Volts) overhead power lines 51' above the ground at the lowest point of the span, having worked many long hours around and under them there is absolutely no related health problems that I'm am aware of and for sure no trees and vegetation that has been retarded in any manner. The power companies do contract with right of ways clearing crews every few years.
That can be a touchy subject, so be careful and have fun. :smile:
  • · Replies 50 ·
14K
  • · Replies 23 ·
