Gravitation vertical mine shaft question
2 replies · 6K views · last reply
homomorphism
Show that, at the bottom of a vertical mine shaft dug to depth D, the measured value of [tex]g[/tex] will be
[tex]g = g_{s}\left(1-\frac{D}{R}\right)[/tex][tex]g_{s}[/tex] being the surface value. Assume that the Earth is a uniform sphere of radius [tex]R[/tex].
[tex]F = \frac{GMm}{r^{2}}[/tex]
[tex]V_{S} = \frac{4}{3}\pi r^{3}[/tex]
I thought you could just plug in [tex](R-D)[/tex] in the force equation but when I looked at the solution they did something with a ratio of masses that looked like this:
[tex]\frac{M(r)}{\frac{4}{3}\pi r^{3}} = \frac{M}{\frac{4}{3}\pi R^{3}}[/tex]
where [tex]M[/tex] is the total mass.
Then the solution went on to this:
[tex]F = \frac{GM_{E}m}{r^{2}}\left(\frac{\frac{4}{3}\pi r^{3}}{\frac{4}{3}\pi R^{3}}\right)[/tex]
I don't really understand these last two steps. Can someone please explain what is happening here, and why are they doing a ratio of masses (related by density) and then multiplying by this ratio?
Right, they are figuring out what part of the Earth contributes to the gravity because as you can imagine, if you are a distance D in a mine shaft, the mass of the ground above you is not going to attract you towards the center of the Earth while the ground below you will. So they used a volume ratio to represent the mass of the Earth still "below" you aka between you and the center
Unfortunately, it's not quite that simple, since that equation expresses the force outside a sphere of mass M and radius R.
What the solution is doing, which crytoguy is saying in another way, is to compare the gravitational acceleration, g_s, at the Earth's surface, to a faked-up planet which has the same average density of Earth, but is smaller in radius by an amount D.
The value for Earth's surface gravity is [tex]g_s = \frac{GM}{R^2}[/tex]; you can use a similar equation for the alternative planet's surface gravity, [tex]g = \frac{GM(r)}{(R-D)^2}[/tex], with r = R - D (I am referring to the solution's manual's notation in part of this).
Putting these pieces together will lead to the desired equation.
