Gravitation with multiple objects by using center of mass
The discussion revolves around the calculation of gravitational forces among multiple objects, specifically four spheres arranged at the corners of a square. Participants explore the appropriateness of using the center of mass of the other spheres to determine the gravitational force on one sphere, addressing both theoretical and practical implications of this approach.
  • Homework-related
  • One participant questions the validity of using the center of mass of the other three spheres to calculate the gravitational force on a selected sphere, noting an error in their approach.
  • Another participant suggests calculating the gravitational force from each sphere individually and then adding the vectors, implying this method is more straightforward.
  • A participant highlights the oversight of not considering the bottom right sphere in the initial calculations, prompting further clarification.
  • Some participants argue that using the center of mass to find the resultant gravitational force does not generally yield correct results, providing a theoretical example to illustrate this point.
  • One participant acknowledges their misunderstanding after receiving clarification about the limitations of using the center of mass approach.
Participants do not reach a consensus on the use of the center of mass for calculating gravitational forces. While some express skepticism about its validity, others remain curious about the reasoning behind its limitations.
Participants discuss the implications of symmetry and the behavior of gravitational forces as distances change, highlighting the complexity of applying center of mass concepts in this context.
XSethX
Four 9.5 kg spheres are located at the corners of a square of side .60 m. Calculate the magnitude and direction of the total gravitational force exerted on one sphere by the other three.
So, essentially my question is, why can I not use center of mass of the other 3 spheres to calculate the gravitational force? I set the top left sphere as my frame of reference, and found the center of mass of the bottom left and top right spheres and calculated the gravitational force at that center of mass on the top left sphere (I narrowed down my error to this part.) Why can I not do this? Thanks in advance!
Edit: Very very sorry, realized I should have posted this in "Introductory Physics Homework"...
I'm not sure exactly why you can't do it, but I also don't see why you would want to do it. I would calculate the force of gravity from each sphere and add the vectors.
By the way, welcome to PF!
What happened to the bottom right sphere?
It won't generally work out if you use center of mass to calculate the resultant gravitational force.
(It is fortunate that it turns out true for planets and such.)
To see why it doesn't make sense as a general rule, consider the following question:
What is the gravitational force at the origin from two identical particles whose positions along some axis are -L+dL and L+dL? We expect (by symmetry) that as we choose smaller dL, the gravitational force should go to zero. Notice though, that the center of mass is a distance dL from the origin; so using your method the gravitational force gets arbitrarily large (we are dividing by dL squared). Clearly incorrect.
I didn't forget, I just calculated that after and added to the number I found. Both times I tried to solve the problem, that value was the same, so I figured my error was with using the center of mass for the bottom left and top right spheres. Thanks!
Yeah, that's how I got the right answer. I was just curious about why using center of mass didn't work. Thanks, though!
Oh, I understand now. Thank you!
  • · Replies 51 ·
  • · Replies 24 ·
  • · Replies 29 ·
  • · Replies 38 ·
  • · Replies 23 ·
