Mentor
- 50,871
- 26,885
This is a valid point; I think everyone commenting in the thread has assumed that the OP actually meant "invariant mass of the system" instead of "weight", but it is good to be precise.Bosko said:Weight is the force that occurs when you place a mass in a gravitational field.
You shouldn't use it because then you would need a third object in whose gravitational field these two (the Sun and Sagittarius A) would be.
This obviously won't apply at the end state of the scenario, where neither of these things are true.Bosko said:Classical Newtonian mechanics when velocities are small compared to the speed of light and when space-time is approximately flat
This won't tell us anything useful. In fact no dynamical analysis is required at all; the question can be answered purely in terms of energy conservation. As has already been done in the thread.Bosko said:Special relativity when the speed of the Sun is not negligible compared to the speed of light, but the Sun is not close to Sag A (space-time of significant curvature).
This is wrong. "Acceleration" due to gravity is not proper acceleration; it is not felt as a force, and therefore relativistic mass as "inertia" (resistance to an applied force) does not apply.Bosko said:Relativistic mass is not "real" mass, but only the body's resistance to acceleration (in this case, the gravitational force of Sag A)
This is implied by the use of a black hole in the scenario, yes. However, in this particular case the analysis looks exactly the same as a Newtonian analysis using energy conservation.Bosko said:General relativity.
