Equation for height as a function of time under gravity
  • Context: Undergrad
  • Thread starter Thread starter nhmllr
    Function Gravity
5 replies · 11K views
nhmllr
If I were to create a function for height affected by gravity (as a function of time) would it be
height = initial upwards velocity * time - gravity * time2
OR
height = initial upwards velocity * time - 2 * gravity * time2
OR something else, and why?
I thought it would be the first one, but after trying to solve some problems, upon checking my work it seems like it would be the second one.
Good answer. But it has small differences.
height = initial height + initial upward velocity * time - 0.5* gravity * time^2
where moving direction is the counter gravity direction.
Doc Al said:
Neither of those are correct. The correct expression would be:
height = initial upwards velocity * time - 0.5 * gravity * time2
(Review the https://www.physicsforums.com/showpost.php?p=905663&postcount=2".)
Ah. After reviewing my work, it turns out that I should have meant to divide by two instead of multiply.
In anycase, what is the reason behind that 1/2? What's it doing that makes it right? It probably has something to do with integrals, because it's in the t2 term, but what?
The acceleration is constant. Integrating once gives the velocity:
v = v0 + at
A second integration gives the position:
x = x0 + v0t + 1/2at2
Setting x = height, x0 = 0, and a = -g, gives the equation you need:
h = v0t - 1/2gt2
v = v0 + at
h = v0t - 1/2gt2
Thanks, I get it now
