Can the Potential Energy of a Rocket Be Calculated Using a Simple Formula?
The discussion revolves around the calculation of potential energy for a rocket during launch, specifically focusing on gravitational potential energy (GPE) and the forces involved. Participants explore the relationship between gravitational force, kinetic energy, and the work done by various forces during the rocket's ascent.
  • Some participants assert that the change in gravitational potential energy (GPE) can be equated to the change in kinetic energy (KE) to find the rocket's velocity at a certain height.
  • Others clarify that GPE represents the work done against Earth's gravitational force, suggesting that this force is inherently accounted for in the GPE calculation.
  • A participant questions the definition of GPE, proposing that it is the work done in bringing a mass from infinity to a point within a gravitational field.
  • Another participant counters that GPE is defined as the work done in moving a mass between two points in a gravitational field, with the potential energy at the initial point being arbitrary.
  • Some participants discuss how changing the reference point for zero potential energy affects the GPE formula, presenting different equations based on the chosen reference point.
  • There is a query about which forces are doing work during a rocket launch, with responses indicating that both gravity and thrust are involved.
  • A participant proposes a formula for calculating potential energy based on thrust and gravitational force, expressing confusion about its validity compared to the GPE formula derived from gravitational force.
  • Another participant emphasizes that potential energy is only applicable to conservative forces like gravity, arguing against the use of thrust in potential energy calculations.
Participants express differing views on the definitions and calculations of GPE, the role of thrust as a non-conservative force, and the implications of changing reference points for potential energy. No consensus is reached on these issues.
Participants highlight the dependence of GPE calculations on the chosen reference point for potential energy, and the distinction between conservative and non-conservative forces in the context of potential energy.
Miraj Kayastha
When a rocket is launched into space, its GPE increases and its KE decreases.
If we equate the change in both energies we can find out the velocity of the rocket at a certain height.
Δ GPE = Δ KE
Does the equation already take the opposing gravitational force of Earth into account?
Δ GPE = Δ KE
Yes. The GPE is represents the work done against the gravitational force of the earth. If it weren't for that force, the potential energy wouldn't increase and the kinetic energy wouldn't decrease.
Isnt GPE the work done in bringing a mass from infinity to a point inside a particular gravitational field?
No, it's defined as the work done in bringing a mass from one point to another in a particular gravitational field, plus the PE at the initial point. The value of the PE that we assign to that initial point is completely arbitrary.
You are thinking of the very useful and widely used convention in which we choose to assign zero to the potential energy at infinity. Then the PE at any other point is, as you say, the (negative of) the work done on bringing a mass in from infinity. However, we could just as reasonably choose to assign zero potential to a point at the surface of the earth, and this choice makes the calculations easier if you're working with a rocket launched from the surface of the earth.
Does changing the position of zero position change the formula of GPE?
Yes. If we define GPE = 0 at r = ∞, then
$$GPE = -\frac{GMm}{r}$$
where M is the mass of the earth, m is the mass of the object in question, and r is the distance from the center of the earth. (This applies only above the surface of the earth)
If we define GPE = 0 at r = R, where R is the radius of the earth, then
$$GPE = GMm \left( \frac{1}{R} - \frac{1}{r} \right)$$
You should be able to check for yourself that both formulas give the same result for ΔGPE between two different values of r.
In this case of rocket launch what force is doing work?
Gravity is doing work on the rocket, and the thrust of the rocket motor is doing work on the rocket.
So can the potential energy of the rocket can be calculated by the formula
(Thrust - Gravitational force) * distance
In my book the gain in GPE of the rocket is calculated by -GMm/r which basically came from integrating Gravitational force* distance
Is there any difference?
I am really confused in the case of rocket launching
Potential energy applies when the work it takes to reach a certain position against a particular force does not depend on the path you take to get there. Gravity has this property. Gravitational force is a "conservative field". So it makes sense to talk about the potential energy of gravity. Thrust does not have this property. So it does not make sense to talk about the potential energy of thrust.
No, because the rocket thrust is not a conservative force. You can define potential energy only for conservative forces such as gravity.
  • · Replies 64 ·
