Greater than 100 percent yield (102%)
The discussion centers on achieving a percent yield greater than 100% in a series of chemical reactions involving copper, specifically Cu(s) reacting with HNO3 to produce Cu(NO3)2, followed by reactions with NaOH, H2SO4, and Zn. The user suspects contamination from residual ZnSO4 and NaNO3 due to inadequate decantation and potential methanol retention during weighing. A participant suggests that the high yield may result from copper contamination with solid zinc, recommending the use of finely divided zinc dust to improve results.
  • Understanding of stoichiometry in chemical reactions
  • Familiarity with percent yield calculations
  • Knowledge of decantation techniques in laboratory settings
  • Experience with purification methods using solvents like methanol and acetone
  • Research methods to improve decantation techniques for better purity
  • Learn about the effects of solvent retention on mass measurements
  • Study the properties and handling of finely divided zinc dust in reactions
  • Explore advanced techniques for calculating and minimizing experimental error
Chemistry students, laboratory technicians, and researchers involved in chemical synthesis and yield optimization will benefit from this discussion.
biochem850
Cu(s) + 4 HNO3 (aq) Cu(NO3)2 (aq) + 2 NO2 (g) + 2 H2O (l)
Cu(No3)2 + 2NaOH -------> Cu(OH)2 + 2NaNO3
Cu(OH)2→CuO + H2O
CuO + H2SO4 -> H2O + CuSO4
CuSO4(aq) + Zn ( s) ------- ZnSO4 (aq)+ Cu(s)
I carried out the follow reactions using copper as an inital product and my percent yield was higher than 100% but I've got some possible error sources. The aqueous solutions which could have possibly remained due to poor decantation are ZnSO4 and NaNO3 and because these substances have high boiling point, they would not be removed when drying the copper using a steam bath and their masses would have an effect? I feel that this is unlikely because we used four washes in which zinc sulfate and sodium nitrate are soluble.
We used methanol and acetone washes right beofre drying the copper and perhaps methanol remained when weighing (because acetone is more volatile)?
In addition, would the highest possible percent error be 2%?
Which product are you asking for?
Copper
There is no such thing as the "highest possible percent error" - error is proportional to the experimentalist clumsiness, and unlimited :wink:
My bet is that your copper is contaminated with solid zinc. Hard to tell not knowing the complete procedure you followed.
Probably Copper is just made a thin layer of precipitation on Zinc piece. Try using finely divided Zinc dust.
22K
25K
51K
