Green's Function Boundary Conditions
8 replies · 3K views
BOAS
I am trying to fill in the gaps of a calculation (computing the deflection potential ##\psi##) in this paper:
http://adsabs.harvard.edu/abs/1994A&A...284..285K
We have the Poisson equation:
##\frac{1}{x}\frac{\partial}{\partial x} \left( x \frac{\partial \psi}{\partial x} \right) + \frac{1}{x^2} \frac{\partial^2 \psi}{\partial \varphi^2} = \frac{\sqrt{f}}{x \Delta(\varphi)}##,
where ##\Delta(\varphi) := \sqrt{\cos^2 \varphi + f^2 \sin^2 \varphi}##.
This is reduced to a nonhomogeneous ODE by the ansatz ##\psi(x, \varphi) = x \tilde \psi(\varphi)##, resulting in
##\tilde \psi + \frac{d^2 \tilde \psi}{d \varphi^2} = \frac{\sqrt{f}}{\Delta(\varphi)}##
The author states that we may solve this equation using Green's method.
(i'm new to this and trying to follow the description here: http://www.damtp.cam.ac.uk/user/dbs26/1BMethods/GreensODE.pdf)
[/B]
So, to begin with, I want to solve the homogeneous equation
##\tilde \psi + \frac{d^2 \tilde \psi}{d \varphi^2} = 0##
However, I am thoroughly confused about the boundary conditions I should employ here. If I use the interval ##[0, 2 \pi]##, which would seem to make sense given ##\varphi## is the polar angle, I end up with nonsense when I compute the homogeneous solutions satisfying the boundary conditions.
To illustrate what I mean:
If ##[0, 2 \pi]## is my interval, then my boundary conditions must be that ##\tilde \psi (0) = \tilde \psi ( 2 \pi) = 0##.
The general homogeneous solution to my equation is ##\tilde \psi = c_1 \sin \varphi + c_2 \cos \varphi##
so I say that ##y_1(\varphi) = \sin \varphi## and ##y_2 = \sin (2 \pi - \varphi)## satisfying the boundary conditions at ##\varphi = 0## and ##\varphi = 2 \pi## respectively.
So my Green's function is
##G(\varphi; \xi) = A(\xi) \sin \varphi## for ##0 \leq \varphi \leq \xi##
and
##G(\varphi; \xi) = -B(\xi) \sin \varphi## for ##\xi \leq \varphi \leq 2\pi##
Applying the continuity condition gives me that ##A(\xi) = - B(\xi)##
and the jump condition ##A(\xi)y'_1(\xi) - B(\xi)y'_2(\xi) = \frac{1}{\alpha(\xi)}##
leads me to the conclusion that ##0 = 1##...
Something is going horribly wrong but I don't know what
Orodruin said:
Your ##y_1## and ##y_2## are not linearly independent.
There is no reason to assume the function value at 0 and 2pi to be zero.
I thought that the conditions on the Green's function meant that for any second order linear differential operator on [a,b], y(a) = y(b) = 0.
That is not true. It depends on the boundary conditions of the problem you are trying to solve. In your case, you are trying to solve an equation with a periodic boundary condition so your Green's function needs to satisfy periodic boundary conditions, nothing more. Note that the choice of what angle corresponds to ##\phi = 0## or ##2\pi## is completely arbitrary and your result should not depend on an arbitrary assignment of coordinates. Furthermore, you could just as well take the interval to be ##[-\pi,\pi)##.
[/B]
and
Back in the Stone Age when I was learning this material we did not worry about boundary conditions on Green's functions. The idea of using a Green's function was just to get some particular solution to the non-homogeneous DE. The homogeneous part of the solution could then be used to impose boundary conditions. So, we can write the solution as
$$\tilde \psi = c_1 \tilde \psi_1 + c_2 \tilde \psi_2 + \tilde \psi_p,$$
where the ##c_i## are constants, ##\tilde \psi_1, \tilde \psi_2## are homogeneous solutions and ##\tilde \psi_p## is any particular solution. If you have boundary conditions on the final solution ##\tilde \psi##, these can be handled by adjusting the constants ##c_1## and ##c_2.##
However, I don't know: maybe things are taught differently nowadays.
I don't like this way of teaching it. It completely obscures the fact that a Green's function with appropriate boundary conditions can be used to take care also of inhomogeneous boundary conditions in many cases.
Edit: Also, in this case we are dealing with a periodic function so the Green's function must be periodic. You cannot just ignore this condition and solve it with boundary conditions (there is no boundary).
[/B]
and
If you want to satisfy ##G(0; \xi) = G(2 \pi; \xi) = 0## as well as continuity of ##G(\varphi;\xi)## and the jump condition on ##G_\varphi(\varphi; \xi)## at ##\varphi = \xi##, you can do it by keeping more constants. For ## \xi \in (0,2\pi)##, let
$$G(\varphi;\xi) = \begin{cases} A_1 \cos(\varphi) + B_1 \sin(\varphi) & \text{if} \; 0 \leq \varphi < \xi\\
A_2 \cos(\varphi) + B_2 \sin(\varphi) & \text{if} \; \xi < \varphi \leq 2 \pi
\end{cases} $$
You have four conditions to be satisfied, and four constants to apply, so it is do-able.
I think @BOAS has the right of it: there is no such Green's function.
If you're looking for a linear combination of sines and cosines then you can write it as [tex]G(\varphi;\xi) = <br /> \begin{cases} <br /> C_1\cos(\varphi - \xi) + D_1\sin(\varphi - \xi) & \varphi \in [0,\xi) \\ <br /> G_\xi & \varphi = \xi \\<br /> C_2\cos(\varphi - \xi) + D_2\sin(\varphi - \xi) & \varphi \in (\xi,2\pi) \end{cases}[/tex] and the conditions to be satisfied at [itex]\varphi = \xi[/itex] are then [itex]C_1 = G_\xi = C_2[/itex] and [itex]D_2 = D_1 + 1[/itex].
Now this function is [itex]2\pi[/itex] periodic in the sense that [itex]G(\varphi;\xi) = G(\varphi + 2\pi; \xi)[/itex] for all [itex]\varphi \in [0,2\pi)[/itex]. However we also require continuity: [tex]\lim_{\varphi \to 2\pi^{-}} G(\varphi; \xi) = G(0,\xi).[/tex] But we don't have this: instead [tex] G(0;\xi) - \lim_{\varphi \to 2\pi^{-}}G(\varphi;\xi) = (D_2 - D_1)\sin\xi = \sin\xi[/tex] which does not hold for all [itex]\xi \in (0,2\pi)[/itex]. (The cases of [itex]\xi \in \{0, 2\pi\}[/itex] - which should yield the same result - need separate treatment anyway.)
Explicitly imposing [itex]G(0;\xi) = G(2\pi;\xi) = 0[/itex] doesn't fix this problem: In @Ray Vickson's notation, you are immediately imposing [itex]A_1 = A_2 = 0[/itex] and are then left with [tex] (B_1 - B_2) \begin{pmatrix} \sin \xi \\ \cos \xi \end{pmatrix} = \begin{pmatrix} 0 \\ -1\end{pmatrix}[/tex] which has a solution only for [itex]\xi = \pi[/itex] - indeed infinitely many solutions in that case.
I hope I've missed something, because otherwise there seems to be a serious error in a published paper (which I have not had the opportunity to read myself).
If you're looking for a linear combination of sines and cosines then you can write it as [tex]G(\varphi;\xi) =<br /> \begin{cases}<br /> C_1\cos(\varphi - \xi) + D_1\sin(\varphi - \xi) & \varphi \in [0,\xi) \\<br /> G_\xi & \varphi = \xi \\<br /> C_2\cos(\varphi - \xi) + D_2\sin(\varphi - \xi) & \varphi \in (\xi,2\pi) \end{cases}[/tex] and the conditions to be satisfied at [itex]\varphi = \xi[/itex] are then [itex]C_1 = G_\xi = C_2[/itex] and [itex]D_2 = D_1 + 1[/itex].
If your first sentence means that there cannot be a periodic Green's function, then I agree. If ##\xi \in (0,2\pi)## implies that
$$G(\varphi; \xi) = \begin{cases} G_1(\varphi), & \varphi < \xi\\
G_2(\varphi), & \varphi > \xi
\end{cases}$$
then the form is pinned down by the anchor at ##\xi##, so that ##G(\varphi + 2 \pi n; \xi) = G_2(\varphi+2 \pi n)## and ##G(\varphi-2 \pi n; \xi) = G_1(\varphi-2 \pi n)## for all ##n \geq 1##. By adding multiples of ##2 \pi## to ##\varphi## we eliminate the "switching" from ##G_1## to ##G_2.## Of course, if we change both arguments we can have periodicity, so that ##G(\varphi \pm 2 \pi n; \xi \pm 2 \pi n) = G(\varphi; \xi)##
