Graduate Green's function calculation of an infinite lattice with periodicity in 1D
The discussion focuses on calculating the Green's function matrix for an infinite lattice with 1D periodicity using the tight binding model. The matrices V and W represent electron hopping within and between unit cells, respectively. The user successfully computed the energy band structure through Fourier transformation and diagonalization. They seek methods for numerically calculating the Green's function matrix, particularly for a subsystem within the infinite lattice, emphasizing the importance of self-energy derived from the surface Green's function of a semi-infinite system.
  • Tight binding model
  • Fourier transformation techniques
  • Matrix diagonalization
  • Green's function theory
  • Study numerical methods for Green's function calculation in infinite lattices
  • Explore self-energy concepts in quantum mechanics
  • Investigate surface Green's functions for semi-infinite systems
  • Learn about embedding problems in condensed matter physics
Physicists, materials scientists, and researchers in condensed matter physics focusing on quantum systems and lattice models.
paulhj
TL;DR
How do I numerically compute the Green's function matrix for an infinitely long lattice with some complicated unit cell?
I am currently trying to compute the Green's function matrix of an infinite lattice with a periodicity in 1 dimension in the tight binding model. I have matrix ##V## that describes the hopping of electrons within each unit cell, and a matrix ##W## that describes the hopping between unit cells.
By Fourier transforming and diagonalising the resulting matrix I have been able to calculate the energy band structure of the system as a function of momentum in the direction of periodicity. Is there then a way of numerically calculating the Green's function matrix of this system, similar to how you can calculate the Green's function for an infinite chain? Any help or recommended reading is much appreciated.
For a finite system, computing Green's function is easy: to compute (zI-H)^-1. If you are only interested in a subsystem of a finite system, the concept of self-energy can be introduced. The self-energy is more helpful when you considering an infinite system. I suppose you want the Green's function of a subsystem inside the infinite lattice, then the problem is an embedding problem: the environment around the subsystem provide self-energy to the subsystem in question, the self-energy can be computed from the surface green function of the semi-infinite system.
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
10K
