Is the Uniformity of Electric Field Between Grounded Metallic Plates Possible?
  • Thread starter Thread starter pcm
    Plates
The discussion centers on the electric field between two metallic plates, where the left plate is grounded and the right plate has a surface charge density, sigma. The user concludes that if the electric field (E) is uniform, it must be zero, leading to a contradiction since the right plate has a charge. The user hypothesizes that the charges may distribute non-uniformly, allowing for a non-zero electric field while maintaining the grounded plate's potential at zero. This indicates a misunderstanding of how electric fields and potentials behave in the presence of charged conductors.
  • Understanding of electrostatics and electric fields
  • Familiarity with the concept of grounded conductors
  • Knowledge of surface charge density and its effects
  • Basic principles of potential difference in electric fields
  • Study the behavior of electric fields between parallel plates with varying charge distributions
  • Learn about the concept of electric potential and its relationship to electric fields
  • Explore the method of images in electrostatics for grounded conductors
  • Investigate the implications of non-uniform charge distributions on electric fields
Students and professionals in physics, particularly those studying electrostatics, electrical engineers, and anyone interested in the behavior of electric fields in conductive materials.
pcm
Suppose there are 2 mettalic plates 1(left)&2(right). Left plate is grounded and right plate is given surface charge density sigma. Now since potential of left plate is 0, so there is no potential difference difference between infinity and plate and since field has to be uniform(?) it has to be zero otherwise there will be potentil diff between plate 1 and infinity . Now suppose the field between the plates is E.
Therefore potential of right plate will be Ed(d is distance between plates )..since field to the right of plate 2 is uniform it has to be zero or otherwise pd between plate 2 and infinity will be infinite..hence I conclude plate 2 is also at 0 potential .so E=0 everywhere which it can't be since I have charge on plate 2. What is wrong with it?
I am assuming plates to be infinite and that on all four faces charge is
uniformly distributed
"possibly" the charges distribute itself in such a way (non uniformly) that field is not zero everywhere, and at the same time potential of grounded plate is zero.
any comments on that...
  • · Replies 31 ·
  • · Replies 58 ·
  • · Replies 26 ·
