What is the structure of an H-decomposable graph?
  • Thread starter Thread starter Robb
H-decomposable graphs are defined by the property that a graph G can be partitioned into subgraphs H_1, H_2, ..., H_k, all isomorphic to a specific graph H. Each subset of edges in G is either isomorphic to H or contains a single edge, ensuring that every node is either part of one of the H subgraphs or has only one edge. This structure allows for isolated pairs of nodes and nodes connected to H graphs, demonstrating the flexibility in constructing H-decomposable graphs.
  • Understanding of graph theory concepts, particularly subgraphs and isomorphism.
  • Familiarity with graph partitioning techniques.
  • Knowledge of basic graph construction methods.
  • Ability to visualize and draw graphs for practical examples.
  • Research the properties of isomorphic graphs and their applications in graph theory.
  • Explore graph partitioning algorithms and their implications in network design.
  • Learn about specific examples of H-decomposable graphs and their construction.
  • Investigate the role of isolated nodes in graph connectivity and decomposition.
Mathematicians, computer scientists, and students studying graph theory, particularly those interested in advanced graph structures and their applications in network analysis.
Robb
Show that if a graph G of size m contains a subgraph H of size m' where m' divides m, then G need not be decomposable.
N/A
Can someone please explain H-decomposable graphs. I understand that if all the subgraphs ##H_1, H_2, ..., H_k## are isomorphic to the same graph H, then G is H-decomposable. What I don't understand is, what is H? I'm reading this as there is a subgraph H, that contains a family of subgraphs ##H_1, H_2, ..., H_k##, which doesn't make sense to me. I thought the subgraphs ##H_1, H_2, ..., H_k## were the decomposition of G. Please advise.
Here is an abstract with a definition of H-decomposition: https://www.scirp.org/journal/PaperInformation.aspx?PaperID=24522. It looks different than what you have stated. In this definition, graph G is partitioned into subsets of the edges, such that each subset is isomorphic to H or contains a single edge. So every node either has only one edge, or is in one and only one subgraph isomorphic to H. The union of these subgraphs and the single edges is G. This leaves open the possibilities of isolated pairs of nodes connected by a single edge and nodes with a single edge connected to an H graph.
Thanks, I don't suppose you would have an example of the graphs G and H, and possibly the partitions?
I don't, but you could construct them yourself. Draw a graph H. It can be any graph - large, small, highly connected or not. Draw a few copies of it. Pick a pair of the H graphs and draw an edge between a node in one and a node in the other. Repeat for another pair of H graphs. You can keep this up until the final graph is connected, or not. If you want you could also add a node connected to one H group with an edge, or a pair of nodes connected with an edge but not connected to anything else.
Likes Robb
THanks
  • · Replies 22 ·
