Half my house is freezing the other half is hot
  • Thread starter Thread starter DaveC426913
The discussion centers on temperature imbalances in a newly acquired n-level backsplit house with central air heating and AC, where one family occupies the lower flat and another the upper flat. The installation of a wall between the two flats has likely disrupted air circulation, leading to the upper flat being too warm and the lower flat too cool. Participants suggest that the existing Nest thermostat may not be sufficient for effective temperature control, and recommend consulting an HVAC professional to evaluate the air distribution system and possibly install additional thermostats or duct modifications. The conversation also touches on the role of air handlers and the importance of proper ductwork for balanced heating and cooling. Overall, addressing the air distribution issue is crucial for achieving a comfortable living environment in both flats.
DaveC426913
TL;DR Summary
What are my options for balancing the A/C in my 3-level backsplit house?
Been in my new house for a month now.
  • It's an n-level backsplit (value of n depends on whom you ask)
  • It has central air heating/AC.
  • There are two families: my wife and I are in the lower flat (red) and our boy and his fam are in the upper flat (blue).
  • Upon closing we had a wall (with door) put in between their flat and ours, (magenta) which was heretofore open.
  • It came with a NEST controller (green) located in their dining room.
  • I do not know if there are any (other?) thermostats in the house.
The problem:
It is too warm up on the top floor, it is optimal on their main floor.
It is too cool on our main floor and it is (naturally) cold in the basement.
Now, that a bit tricky, since we sleep on our main floor, and it's got to be cool.
I don't really know how these Nest things work. You can buy thermostats as separate units and distribute them about the house.
I don't know if the controller itself also acts as a thermostat. So I don't know if there should be at least one thermostat somewhere in the house. We have not found any. It would not surprise me if the previous owners tossed them in a box while packing. Do I need to have at least one? Should I get another?
My boy is talking about a booster (which has nothing to do with the Nest technology). It sounds like it's just a fan to help the air reach farther rooms.Help?
Location of air handler unit(s)?
It seems that the magenta new wall has blocked the free return of the suplied air back to the air handler unit.
Likes russ_watters
I'm not sure of your HVAC setup, but I doubt it's the thermostat that's the problem. Unless you have individual control of different HVAC circuits, one thermostat can't do it. Even if the controller(s) could say heat the lower level but not the upper level, or vice-versa, could your HVAC system do that? All one thermostat can do is set a good average temperature.
Normally there is some relatively fixed ratio of flow between different rooms controlled by dampers (valves) or register vents. That may need to be addressed. Why not hire an HVAC guy to come in and make some suggestions or adjustments?
Likes russ_watters and DaveC426913
What's an air handler unit? (I've never lived in a house with central air, so the only central thing Ive ever known is a furnace)
There's the big contraption with the air ducts in the basement, and there's an AC blower thingy outside.
It's like your old furnace with a big fan, but it can probably also cool the air, so they gave it a newer name. Air comes in, is heated, cooled, dehumidified, filtered, etc., and is then blown out to the house with a fan.
https://www.trmillerheatingandcooling.com/a-comprehensive-guide-to-air-handlers/
Your question suggests that you will need assistance from an AC company in evaluating and remediating the air distribution problem that you have.
They will probably need to install a transfer duct that solves the interference to the path of air that the new wall has created (especially if the top end of the stairs to the basement is on your side of the house).
They can also do a test and balance of all the diffusers and grilles in the house in order to achieve a better air distribution via the central duct system.
If all that fails, they can install duct automatic dampers controlled by thermostats located at the four main zones and/or duct booster fans where needed.
Please, see:
https://www.thisoldhouse.com/heatin...s-before-you-install-central-air-conditioning
Likes russ_watters and Tom.G
It may help a lot if you check the comfortable temperatures for every area first, since it may differ depending on external circumstances (with different wording: you may feel the same air temperature hot or cold depending on external circumstances).
Can you mark on the drawing the location of all supply and return grilles? More pointedly; is there one return in each room or just a single big one in the basement by the big contraption with the air ducts air handler?
This is no doubt a balancing (where the air is going) problem that may have been caused/exacerbated by putting in the wall.
You may just need to close supply grilles where it is cold. ...and may also need a transfer duct/grille.
You have one ac unit so one thermostat. That isn't a problem.
Central air and central heating are basically the same: a furnace is also an air handling unit.
Likes Bystander and Lnewqban
Furnace: A big sheet metal box. When the house gets cold the box starts a fire and blows the hot air into the house.
Air Conditioner: A big sheet metal box. When the house gets hot the box gets cold by moving its heat outdoors (just like your refrigerator does). The cold box then blows the cold air into the house.
Both fall under the umbrella name of an "Air Handler System."
For efficency, each of them accepts already heated (cooled) air from the house, heats or cools it again, then sends that air back into the house.
It sounds like your new wall may have blocked the heated (cooled) air from returning to those sheet metal boxes.
The "Nest" is just a thermostat with a tiny 'brain' added, and, like anything tiny, can't really do much beyond telling the heater or cooler to turn On and Off.
Hope this helps!
Cheers,
Tom
Likes russ_watters and Lnewqban
The Nest and also Hive do more than just provide a thermostat. Firstly, they can operate a number of different independent zones within the house. Secondly, they will give you a 'Ready By' facility which will establish a zone temperature by turning the boiler on at a time so that your room is the required temperature 'by' your chosen time. My Hive also gives you a graph or temperatures over the day and tells you when the boiler was actually switched on.
So it's an above average residential grade thermostat...
I have a Honeywell Residio T9, with all of the above as well. Multi-zone sensing without independent control can be problematic, but for me as the only one in the house it enables me to select (or motion sense) which room I'm in for control. For @DaveC426913 multi-zone sensing would be informative and may help with balancing and allow averaging the readings. You can buy add-on remote sensors for the Nest.
Yeah but only if your house is set up with independent zones and ducting actuators to service them.
I see this as stuff for enthusiasts. I don't really want to turn my household climate needs into a hobby.
Likes russ_watters and Bystander
Not exactly. You can pick which sensor gets "satisfied" or average them. It also provides information on where you need to direct the airflow rather than just relying on feel.
Likes DaveC426913
DaveC426913 said:
TL;DR Summary: What are my options for balancing the A/C in my 3-level backsplit house?
I've heard of cases where the builder didn't put in return ducts where they should have. You need a thermostat in the upper floors that determines when the AC unit runs, and you need one in the lower floors to determine when/if to open a duct to the lower floors. In the winter it will be opposite. In the mean time go to the thermostat and set it so the fan goes full time. The booster may be necessary. The lowest floor will always be too cold unless you have heat available. Is it noticeably different if you leave the door open? I would guess not. I have a 2-level house with a door at the bottom of the stairs. It doesn't make a lot of difference. I use an electric heater in the room I am in often downstairs.
Likes russ_watters
"Surely you jest...and the inspectors didn't catch it?" Goes on all the time.
I'm the 2nd owner of my house; about 3 years old when I bought it. Soon after, I went into the attic for a look-around, and the main return duct for upstairs was just sitting there open to the attic next to the distribution header it was supposed to be connected to. Prior owner spent 2 summers with it like that.
  • Wow
Likes sophiecentaur
I only have experience of wet CH systems. Warm Air CH was popular for a short while in the UK during the 60s and not since (afair). Water valves are very easy for controlling zones and, of course, under-floor heating mixes well. But local rules apply for so many aspects of domestic engineering.
PF has given me another surprise with all this talk of air ducts and the like. Where are the advantages with air, especially when the living volume of new homes is reducing on a yearly basis?
No boiler is one big advantage. The basic engineering can be really simple. A fire, a fan, and a bunch of tubes.
Likes russ_watters
Heating and cooling in one piece of equipment.
Prior to the advent of air conditioning it was much more common to see hydronic heating solutions. But now that almost everyone has air conditioning it s much more common to see central air based systems. In the UK are fewer people have air conditioning and those who do run it for much less than is run in the us. So nobody cares about the crappiness of window air conditioners.
I work with a uk-based client and their engineers don't get how much hotter and colder it is in the US than in the UK. And sorry Dave, Toronto is essentially northeastern US.
Other side of the coin of course is that until I looked up the stats after that bad heat wave last year I had no idea how few people have air conditioning in the uk.
Also I don't know about the UK or Canada but in the US house sizes continue to get larger.
Not in California. The choice now days is big homes or a tent under the freeway.
Likes nsaspook, berkeman and russ_watters
russ_watters said:
Wow. A different world in UK. Compact living has been the norm for people moving into recently built homes. A recent law has attempted to change building regs to increase the area per person but this may be a two edged sword because it means new builds may become too expensive. This will be more so as the mortgage interest increases have resulted in repayments being beyond the means of so many people.
But the areas of rooms in the majority of UK decreased steadily since WW2. It's often a selling point for more elderly homes.
But the same Physics applies on both sides of the Atlantic. [Edit: are there no commercial pressures to limit house prices?]
In the Bay Area and LA it's all land cost. If you can afford the land, you'll spend a bit extra to build a big house. Much of this is the decline of urban housing in favor of suburbia. Developers make more money building big houses on expensive land. Suburban infrastructure doesn't support small living very well.
There are a couple of great divides at work polarizing the market: Affluent white collar types vs. Declining blue collar families; and desirable growing economic areas vs. declining areas. Houses are cheap in Detroit, but everyone still wants to move to LA where they aren't cheap because of employment.
This drives much of the political polarization here. Which I can't talk about without getting in trouble, LOL.
Likes sophiecentaur and russ_watters
Yeah, in the US/CA we have a lot of space so we spread out, and big houses seem to be part of that. This says for current new houses anyway the US and CA are similar and more than double the size of those in the UK:
https://shrinkthatfootprint.com/how-big-is-a-house/
Not much apparently. As @DaveE says, a lot of people move to California and buy big/expensive houses and then complain about the price and/or commute but they still do it.
Dunno. My home is 3400 square feet. (That's actual, not Real Estateeze)
Including garage? That's really big to only have one HVAC system. Do you happen to know the capacity? It's probably in the model number on the sticker on the outdoor unit (condensing unit).
Not including garage. But it is including finished basement (which might not have been in the specs when the system went in).
I'll check the capacity.
Likes russ_watters
So what do people do for hot water? Plumbing effort must be a lot less than installing ducts - especially if you suddenly need to re-route.
The dry / wet system arguments put me in mind of the endless 120/240V, ring main, two phase mis-understandings we get into so often.
but not in UK?
Wander around a 'show home' on a new development in UK and note the special small furniture that's placed so you don't notice the matchbox sizes of some rooms. UK is in a special situation with regard to land availability and many 'new world' countries don't have that problem.
Otoh, look at the millions of tiny apartments in large cities all over the world. That started off in the Soviet style blocks that dear old Joe Stalin put up.
sophiecentaur said:
UK is in a special situation with regard to land availability...
Are they?
Is it that there isn't enough land, or is it - like here in Canada - that the only land people want is in cities?
Because, for a tiny nation, UK seems remarkably rife with green space.
Likes russ_watters
A stand alone water heater. What do people do in the UK for domestic hot water? The systems have to be separate, but could be linked via heat exchanger. That's common in commercial or apartment buildings here.
Again, you seem to not be considering air conditioning. This logic doesn't hold when you have both heating and air conditioning.
I don't understand what you mean.
  • #31
Can you deduce anything from this?
  • #32
030 in the model number means 30,000 BTU or 2.5 Tons. It's about half the capacity I expected. By comparison I'm in Philadelphia and my 1,500 sq ft townhouse has a 2.5 Ton unit.
Are there areas of the house with no supply vents? You only have one of those outdoor big fan cube thingies condensing units, right?
  • #33
I'm about twice as far north?
I don't think so. Would a basement normally have vents?
Yes.
  • #34
Twice as far as what? You're about 220 mi north of me. Anyway I checked design weather data and your 0.4% design day (it is hotter 0.4% of the time) is 89F whereas mine is 91F. Not that far apart.
For the record, London: 83F, 700 mi north of Philly.
Finished basements sometimes but not always.
Anyway, if it is overall cool enough so be it.
  • #35
Play on words (and, I guess, numbers).
Likes russ_watters
  • #36
A single boiler for CH and water. There are options of a hot water tank or a combi boiler. Only one expensive item and two plumbing circuits. But AC has not been commonly used in UK. A proper Energy policy with home insulation would see things that way, even with climate change.
Dry = Hot air. Wet = radiators. Two different approaches which seem to be mutually foreign to UK and US. An analogue to the clash of cultures about electricity supply. As usual there are good reasons for either but we all make assumptions about what the other guy does..
There, in Canada, you have land, lots of land. Green belt has been jealously guarded and Nimbyism rules in UK. Urban living is popular but folks can't afford their mortgages. It was pointed out, today, that mortgages in the US are usually for long terms at a fixed interest rate. These days, in UK, interest is seldom fixed for more than a very few years. That's another difference between east and west.
  • #37
sophiecentaur said:
Dry = Hot air. Wet = radiators. Two different approaches....
Fair enough....we call it "central air" here and it confused me to call it "dry' due to all the water pouring down the drain...
...which seem to be mutually foreign to UK and US. An analogue to the clash of cultures about electricity supply. As usual there are good reasons for either but we all make assumptions about what the other guy does.
Yeah, it's the different requirements/constraints that make most of the difference. The design choices do make sense in context.
But I just realized....
I'm working on an all-electric/zero carbon lab project, and we had a very hard time finding air source hot water boilers. Our major equipment vendor had never sold one in the US and had to lean on their European division for assistance. Even still, product options are very thin and there are many available in Europe/Asia that are not available in North America. And I just realized why: When Northern Europe electrifies, they will easily convert from natural gas and oil boilers to heat pump boilers whereas in the US all our residential and light commercial heat pumps are forced air. We simply don't have anywhere near the market for a heat pump boiler as exists in Europe. Also, ginormous natural gas reserves, so less geopolitical pressure.
Likes sophiecentaur
  • #38
Can't you just put in a small window AC unit upstairs? Then you can use less central AC on the main floor.
  • #39
Why not just use a fan and some ducting to get warmer air into the cooler rooms? A/C involves yet more electrical power input and, of course, it's expensive to buy.
Likes russ_watters
  • #40
Ceiling fans can mix up the air. There are two settings, one for summer and one for winter. The upper fans could be used to push the hot air down and the lower fans to pull the cool air up.
  • #41
I wasn't proposing a ceiling fan. I was thinking in terms of a large diameter, slow, 'extractor fan'. The big ones shift a lot of air (good for smokey kitchens) and are bidirectional. Trunking etc. is always available to fit the popular ones. You could annoy your house sharers by pumping curry / steak aroma into their half.
The logic of the ceiling fan (Punka) is to blow air downwards in summer and upwards in winter - or is it the other way? :wink:
Likes russ_watters
  • #42
To return to the original question in the OP, I think that the comments about the return vent are spot on. Might be worth patching in another return duct on the side without one, or to put a vent between sections to allow crossflow.
Another possibility, though much more complicated, would be some sort of proportioning valves in the ducts to force air at different rates to different areas. The issue I see with that beside the complexity is the controls. You'd basically have to reverse the proportions as the seasons change, i.e. more flow downstairs in the winter for heating, more flow upstairs in the summer for cooling.
  • #43
You recently retired?
