Half wave dipole antenna physics
4 replies · 2K views · last reply
midz99
First time poster long time reader.
If i have a half wave dipole antenna with a certain length and I am using a VCO to drive that antenna at lower driving frequency do i get EM at the length of twice the length of the antenna but just at a slower emission rate?
example, if i have a half wave dipole antenna measuring 6.25cm and I am using a VCO to drive that antenna at only 1ghz where i should be using 2.4ghz, will that antenna still emit EM at 2.4ghz but at a rate of 1ghz?
The antenna only radiates the frequency of the VCO. If it is of the "wrong" length, then efficiency is reduced, but frequency is unaltered.
The EM wave is always radiated/emitted at the speed of light
As tech99 said the emission will be poor
This is because the antenna isn't resonant for the 1 GHz frequency from the VCO
i think you miss understand what i meant by emission rate, each cycle back and forward of electron movement creates EM, now if the driving frequency was 2GHz then emission rate would be 2GHz. The distance an electron travels before its return trip directly corresponds to the wavelength of EM you get. but if that distance is restricted by length of the material, so it doesn't travel far enough how do you still get the same wavelength as the driving frequency?
forget about the term emission rate ... isn't a term used for RF and antennas ... use frequency
The RF signal is emitted at the speed of light regardless of its frequency
no, the electrons just oscillate about a point at the given frequency. The distance they move at 2GHz is nigh microscopic in length
that has already been answered above by tech99 and myself
BTW this thread shouldn't be labelled A for advanced, when you don't even have an understanding of the basics
Dave
