Hamiltonian of a 1D Linear Harmonic Oscillator
The Hamiltonian for a one-dimensional linear harmonic oscillator is defined as H = (1/2)(P^2 + ω^2 X^2) - (1/2)ωħ, where P and X are the momentum and position operators, respectively. The discussion clarifies that the terms [P + iωX] and [P - iωX] do not correspond to directional momentum but rather represent operator forms. The Hamiltonian can be derived from the Schrödinger equation -ħ/(2m)(d²Ψ/dx²) + (1/2)mω²x²Ψ = EΨ, and the constant term - (1/2)ωħ is an arbitrary additive constant chosen to set the ground state energy to zero.
  • Understanding of quantum mechanics principles, particularly Hamiltonian mechanics.
  • Familiarity with operator notation in quantum mechanics, specifically momentum and position operators.
  • Knowledge of the Schrödinger equation and its applications in quantum systems.
  • Basic understanding of harmonic oscillators and their mathematical representations.
  • Study the derivation of the Hamiltonian for various quantum systems, focusing on the harmonic oscillator.
  • Learn about the significance of the ground state energy in quantum mechanics and how it affects system behavior.
  • Explore the concept of operator algebra in quantum mechanics, particularly commutation relations.
  • Investigate the role of additive constants in Hamiltonians and their implications for physical systems.
Students and professionals in physics, particularly those specializing in quantum mechanics, theoretical physicists, and anyone studying the properties of harmonic oscillators in quantum systems.
Patrick McBride
Show that for the one-dimensional linear harmonic oscillator the Hamiltonian is:
[; H = \frac{1}{2}[P^2+\omega ^2 X^2]-\frac{1}{2}\omega \hbar ;]
[; =\frac{1}{2}[P+i\omega X][P-i\omega X]+\frac{1}{2} \omega \hbar ;]
where P, X are the momentum and position operators, respectively, and [; X= \sqrt{m}x ;].
[; X= \sqrt{m}x ;] [; P = p/ \sqrt{m}} ;]
Sch. Eqn.: [;-\frac{\hbar}{2m}\frac{d^2\Psi }{dx^2}+\frac{1}{2}m\omega^2x^2\Psi = E\Psi ;].
[/B]
So as from what I can tell [; [P+i\omega X] ;] refers to the +x direction and [;
[P-i\omega X] ;] is in the -x direction. The momentum operator is going to be [; P = p/ \sqrt{m}} ;].Sch. Eqn.: [;-\frac{\hbar}{2m}\frac{d^2\Psi }{dx^2}+\frac{1}{2}m\omega^2x^2\Psi = E\Psi ;].
So what I assume is Sch.Eqn. must be solved algebraically. From there we can get our Hamiltonian.
Any suggestions?
where P, X are the momentum and position operators, respectively, and ##X= \sqrt{m}x##.
X= \sqrt{m}x ~~~~~P = p/ \sqrt{m}
Sch. Eqn.:
[/B]
So as from what I can tell ## [P+i\omega X] ## refers to the +x direction and ##
[P-i\omega X] ## is in the -x direction. The momentum operator is going to be ## P = p/ \sqrt{m} ##.Sch. Eqn.: ##-\frac{\hbar}{2m}\frac{d^2\Psi }{dx^2}+\frac{1}{2}m\omega^2x^2\Psi = E\Psi ##.
Any suggestions?
I corrected all your TeX tags so that the equations will show up properly.
First:, the ## P \pm i \omega x ## have nothing to do with momentum along +x or -x, each P is actually ##P_x## and may be positive or negative.
The Hamiltonian is simply the operator H in ## H \psi = E \psi ## so you may read it off directly from the Schrödinger equation that you wrote. Then to show the second form, you may simply expand out the second form and use what you know about the commutator of P and X.
Ok so I had a crack at it and this is what I've gotten:
## \frac{P^2}{2m} +\frac{1}{2}kx^2 =H ## Harmonic Oscillator Hamiltonian
## -\frac{\hbar^2}{2m} \frac{d^2\Psi }{dx^2}+\frac{1}{2}kx^2 \Psi = E \Psi ## Schrödinger Equation for energy eigenstates.
## \omega =\sqrt{\frac{k}{m}} ## Replace spring constant with classical oscillator frequency.
## \frac{p^2}{2m} = \frac{1}{2}(\frac{p}{\sqrt{m}})^2 = \frac{1}{2}P^2 ## Simplifying using the momentum operator ##P##.
## X^2 = (\sqrt{m}x)^2 = mx^2 ## We can do the same for our position operator ##X##.
## H =\frac{1}{2}P^2 + \frac{1}{2}\omega ^2 X^2 = \frac{1}{2}(P^2 +\omega^2 X^2) ## Subbing into our equation for ##H##.
That explains everything except ##-1/2 \omega \hbar ## from the first equation.
Am I missing something?
Good work.
The hamiltonian is actually defined up to an additive constant, that is one can *define* the Hamiltonian to be what you got plus any constant energy. This added constant is arbitrary. It is usually taken to be zero, in which case your expression would be the final answer. But what they did here is to choose the constant in such a way that the expectation value ##\langle 0 | H | 0 \rangle =0## , in other words they wanted the ground state energy to be zero (they should have mentioned that in the question, if they did not, they were not very clear). You probably know that the expectation value of the Hamiltonian in the ground state is usually given as ##\hbar \omega/2##, that's what you would get with your expression. So they decided to subtract that value from your H H in order to achieve, with their hamiltonian, ##\langle 0 | H | 0 \rangle =0##.
nrqed said:
Good work.
Cool, thanks for the explanation really helped out.
  • · Replies 16 ·
