Hamilton's equation and Euler-Lagrange's equation comparison
  • Thread starter Thread starter JD_PM
    Comparison
The discussion centers on the comparison between Hamilton's equation and Euler-Lagrange's equation, specifically addressing the relationship between the Hamiltonian (H) and the Lagrangian (L) in the context of a given Lagrangian defined as \(L = \frac{1}{2} G_{ab} \dot{q}^a \dot{q}^b\). Participants highlight that while it appears \(H\) can equal \(L\) under certain conditions, this is misleading as the Hamiltonian is fundamentally a function of \(q\) and \(p\), not \(q\) and \(\dot{q}\). The discussion concludes that the equality \(H = L\) is incorrect due to the differing dependencies of \(H\) and \(L\) on their respective variables.
  • Understanding of Hamiltonian mechanics and Lagrangian mechanics
  • Familiarity with the concepts of momentum and kinetic energy in classical mechanics
  • Knowledge of partial derivatives and their applications in physics
  • Proficiency in mathematical notation used in physics, particularly in the context of equations of motion
  • Study the derivation of Hamilton's equations from the Lagrangian formulation
  • Explore the implications of the Legendre transformation in classical mechanics
  • Investigate the conditions under which the Hamiltonian and Lagrangian can be equivalent
  • Learn about the role of generalized coordinates and momenta in Hamiltonian mechanics
Students and professionals in physics, particularly those focused on classical mechanics, as well as researchers exploring the foundations of dynamical systems and their mathematical representations.
JD_PM
I will not use summation sign: repeated pair of (upper and lower) indices are summed over: [itex]\sum_{a} A_{a} B^{a} \equiv A_{a}B^{a} = A_{c}B^{c}[/itex] (summed over indices are dummy indices so you can rename them as you like).
Let ##V(q) = 0##. Then the Hamiltonian (##H = T + V##) and the Lagrangian (##L = T - V##) are equal:
$$H = L = 1/2 G_{ab} \dot q^a \dot q^b \ \ \ \ (1)$$
Show that you get ##(1)## either using Hamilton's equation ##\dot{p}_k=\frac{\partial L}{\partial q^k}## or Euler-Lagrange equation ##\frac{d}{dt} \Big(\frac{\partial L}{\partial \dot q^k }\Big) = \frac{\partial L}{\partial q^k}##
$$H = L = 1/2 G_{ab} \dot q^a \dot q^b$$
$$\dot{p}_k=\frac{\partial L}{\partial q^k}$$
$$\frac{d}{dt} \Big(\frac{\partial L}{\partial \dot q^k }\Big) = \frac{\partial L}{\partial q^k}$$
We know that the momentum for such a lagrangian is:
$$p_k = \frac{\partial L}{\partial \dot q^k} = 1/2 \Big( G_{ab} \delta_k^a \dot q^b + G_{ab} \delta_k^b \dot q^a\Big) = 1/2 \Big( G_{kb} \dot q^b + G_{ak} \dot q^a\Big) = G_{ak} \dot q^a$$
OK so using Hamilton's equation we get (and recalling that ##L = H## for this particular problem):
$$\dot p_a = -\frac{\partial H}{\partial q^a} = -\partial_a H = -1/2\partial_a G_{cb} \dot q^c \dot q^b \ \ \ \ (2)$$
By using ##\frac{d}{dt} \Big(\frac{\partial L}{\partial \dot q^k }\Big) = \frac{\partial L}{\partial q^k}## we get:
$$\frac{d}{dt} \Big(\frac{\partial L}{\partial \dot q^a }\Big) = \frac{d}{dt}\Big( G_{ab} \dot q^b\Big) = \frac{\partial L}{\partial q^a} = 1/2\partial_a G_{cb} \dot q^c \dot q^b \ \ \ \ (3)$$
Mmm so there's a sign difference between ##(2)## and ##(3)##. They should be equal. Why am I wrong?
I can't figure out what you are trying to do.
All I could think of is
a) Take ##L = \frac 1 2 G_{ab}\dot q^a \dot q^b##
b) Define ##H = p_k\dot{q}^k - L##, where ##p_k = \frac{\partial L}{\partial \dot q^k}##.
c) Show that ##H = L##.
Is that the exercise?
You need to be very careful here. Even if you have no potential energy, the Hamiltonian and Lagrangian cannot be the same because the Hamiltonian is a function of ##q## and ##p## while the Lagrangian is a function of ##q## and ##\dot q##. Since the relation between ##p## and ##\dot q## generally depends on ##q##, the partial derivative of the Hamiltonian wrt q is not equal to the partial derivative of the Lagrangian wrt q. That is, generally
\frac{\partial L}{\partial q} \neq \frac{\partial H}{\partial q}
even if ##H = L## under the identification ##p = \partial L/\partial \dot q##.
What you suggest is to do the following exercise:
Show that ##H = L## given ##L = \frac 1 2 G_{ab}\dot q^a \dot q^b##, ##H = p_k\dot{q}^k - L## and ##p_k = \frac{\partial L}{\partial \dot q^k}##
Solution:
$$H = p_a\dot{q}^a - L = G_{ba} \dot q^b \dot q^a - \frac 1 2 G_{ab}\dot q^a \dot q^b = \frac 1 2 G_{ba} \dot q^b \dot q^a$$
So indeed
$$H = L$$
But based on what Orodruin said, this cannot be correct because 'the Hamiltonian and Lagrangian cannot be the same'...
Mmm I do not get your reasoning, could you please explain your argument based on an example?
Besides, why is the above exercise proposed by PeroK wrongly solved?
Solution:
So indeed
$$H = L$$
Technically we have a third function, which I'll call ##H'##:
##H'(q, \dot q) = H(p(q, \dot q), \dot q)##
In this case ##H' = L##.
  • Love
PS The following appears a lot in physics texts:
You have some function ##\psi(x)##, say, and a change of variable ##x = f(y)##. Which leads to ##\psi(y)##. But, in fact, what we really have is a new function:
##\psi'(y) = \psi(f(y))##
To take an example. If ##\psi(x) = \sin(x)## and ##x = 2y##, then:
##\psi(y) = \sin(y)## (technically, as ##\psi## is simply the sine function)
But:
##\psi'(y) = \sin(2y)##
Is what's really meant. If we are taking about a real wave amplitude, say, then ##y = \pi/4## means ##x = \pi/2## and the amplitude should be ##1## when ##y = \pi/4## . Which it is for ##\psi'## but not for ##\psi##.
  • Love
JD_PM said:
Solution:
H=pa˙qa−L=Gba˙qb˙qa−12Gab˙qa˙qb=12Gba˙qb˙qa​
This is incorrect because, as already mentioned, the Hamiltonian is a function of q and p, not q and ##\dot q##. You obtain the Hamiltonian from the Lagrangian by insering ##\dot q## as a function of q and p where ##p = \partial L/\partial \dot q##.
Take the simplest example ##L = m \dot q^2/2##. You would find that ##p = m\dot q## and therefore ##\dot q = p/m## leading to ##H = p^2/(2m)##. Here, neither L or H depend on q so the partial derivatives both vanish. However, this would not be the case if you let m depend on q.
Oh I think I see it now. The issue is that we get a function (which you labeled ##H'##) which is a function of ##q## and ##\dot q##. By definition this cannot be the Hamiltonian, as ##H(q, p)## is certainly not ##H'(q, \dot q)##. Thus we need to apply a change of variables to get the Hamiltonian out of ##H'(q, \dot q)##; in this case we need ##\dot q = p(q, \dot q)##.
By the way, I think there is a typo in #6;
I get:
$$H'(q, \dot q) = H(q, p(q, \dot q))$$
Where I've used the change of variables ##\dot q = p(q, \dot q)##
Instead of ##H'(q, \dot q) = H(p(q, \dot q), \dot q)##
Do you agree?
I get:
Do you agree?
Hmm ... I guess it depends what we mean by the "Hamiltonian". Like the Lagrangian, it takes a different form in different coordinates.
If we take ##L, H, H'## to be specific functions (of specific variables), then we need to stay consistent in what these mean.
The way I defined ##H## in post #3 I think is consistent with post #6.
Your Hamiltonian is a function of ##p## and ##\dot q##. I think that the Hamiltonian has to be ##H(q, p)## (by definition) instead.
How do you define it?
This is correct.
What he is saying is that you wrote that the Hamiltonian is a function of ##p## and ##\dot q##. It is a function of ##p## and ##q##.
Orodruin said:
...he...
He/she/bot ... :rolleyes:
OK So my answer to #1 would be:
This exercise is faulty; let's argue why
It asks to show that
$$H = L = 1/2 G_{ab} \dot q^a \dot q^b \ \ \ \ (1) $$
We know that ##L(q, \dot q) = 1/2 G_{ab} \dot q^a \dot q^b##
But
$$H'(q, \dot q) = p_a\dot{q}^a - L = G_{ba} \dot q^b \dot q^a - \frac 1 2 G_{ab}\dot q^a \dot q^b = \frac 1 2 G_{ba} \dot q^b \dot q^a$$
And of course
$$H'(q, \dot q) \neq H(q, p)$$
Thus ##(1)## should be:
$$H(q, p) \neq H'(q, \dot q) = L(q, \dot q) = 1/2 G_{ab} \dot q^a \dot q^b \ \ \ \ (1) $$
I think I got it! Thank you both :)
WoW I am learning a lot these days...
I get:
Do you agree?
Yes, you're right. The correct functional form of ##H## is as a function of ##q, p##.
  • · Replies 81 ·
  • · Replies 16 ·
