Handwaving to match orders of magnitude
In summary, the conversation discusses various hand-waving arguments and examples in the fields of astrophysics and physics, such as estimating the number of stars in the universe and the strength of a nuclear blast using simple methods. The conversation also touches on the concept of the photon's rest mass and its potential impact on the mass of the universe, as well as the possibility of an infinite universe based on observations of the sky. The contributions of Enrico Fermi to these topics are also mentioned.
swle
Hello
This is my first post here. Although I've often read posts in Physics Forums, I've never actually contributed anything - so here goes!
I always enjoy a good hand-waving argument on orders of magnitude; when I first started my astrophysics degree, one homework question was "estimate how many piano tuners there are in this town" - that was it, no other clues! Of course, it was designed to get us to think of ways of solving a problem by making realistic guestimations. Another argument I admired goes that there cannot be an infinitie number of stars in the universe otherwise there would be an infinite amount of light in the sky, so we would not expereience darkness at night.
Anyway, I was sitting in the library today (should have been working on a Solid State problem) and started wondering: if I took the energy of a photon as a "rest mass" and multiplied it by the number of photons in the universe would that be anywhere close to the estimated figure for dark matter? So I looked up some figures from not-very-reputable sources (this is just hand-waving, after all) and got this:
Number of photons in the universe: 10^91 (source: Science Blog)
"Rest Mass" of a photon: 4.2 * 10^-40 kg (source: Wikipedia)
So, total estimated photon "Rest Mass" = 4.2 * 10^52 kg.
Now compare to Dark Matter in the Universe: 3.5 * 10^52 kg (source: Wikipedia)
They match within 20% - well within an order of magnitude!
Well, I thought it was interesting even if doesn't mean anything!
Anyone got any other hand-waving examples that they can think of?
Science news on Phys.org
Photon has no rest mass, so I have no idea what you are doing. Or why.
Your estimates cannot be remotely right, however. They suggest that gravitational mass in radiation is significantly greater than gravitational mass of matter in the universe. That would, indeed, result in our sky being a touch on the bright side.
Actually, that's only true if distribution is uniform. If there is an infinite universe with star density is being a fractal, it's possible to achieve finite luminance of the sky. And since distribution of matter agrees with it on scales we do observe, the universe could still be infinite based on our observation of the sky.
That is the upper limit on the mass of the photon. We do not actually have any unambiguous experimental evidence that the photon has mass. This upper limit is simply a measure of the finite precision of our best experimental results. The mass could be that big and still "look like" zero as far as our experiments are concerned.
Have you ever seen a graph with error bars on the data points? The upper limit is basically the top edge of the error bar, with the actual data point being at somewhere around zero.
I think estimating the strength of a nuclear blast using some bits of paper ranks pretty highly.
then again, I think both that example and the piano tuning are due to Enrico Fermi.
Heres a nice little story on it for those curious: http://sci.mercer.edu/handouts/fermi_calculations.htm
Thank-you for taking time to reply!
Like I said, just a bit of fun!
I don't follow that argument - perhaps you cold explain?
I don't follow this argument either, perhaps you can explain this one too? The universe may well be fractally distributed, but as far as we know it is isotropic? Treatment of the improper integral is fairly straightforward?
Is your argument that a finite number of stars are visible (so the sky is dark at night) but an infinite amount of stars could exist at an infinite distance so that we would never see their light (i.e. a non-bigbang solution)?
Brilliant - thanks!
Thanks for reply!
It was just a bit of fun - I realize that most objections will centre around what is, or what is not, "rest mass". I took the view that if someone is prepared to quote a figure, then I am prepared to put it into a calculation!
Suppose we have an infinite space filled with identical stars distributed with an average density of ρ. How much light are we going to receive from stars distance R away? N/R², where N is number of stars at that distance. Of course, if we take continuous limit, the total illumination becomes:
[tex]\int_0^\infty \frac{dN}{r^2} = \int_0^\infty 4\pi\frac{r^2 \rho dr}{r^2} = \int_0^\infty 4\pi\rho dr = \infty[/tex]
So we will get infinite luminosity. Now imagine, instead, that stars are grouped into clusters of density ρ. These clusters are spread out a bit more from each other, so if you take average density across groups of clusters, the new density is some ρ'<ρ. These groups are also clustered, and that gives you density on even larger scale to be ρ''<ρ'<ρ. Because we live near a star, which belongs to a cluster, which belongs to a group of clusters, etc, locally we have the highest density of stars, and it drops with distance. So ρ(r) is now a decreasing function. Say, ρ(r)=ρ0exp(-λr) just for illustration. Now the total luminosity is different.
[tex]\int_0^\infty \frac{dN}{r^2} = \int_0^\infty 4\pi \rho_0 e^{-\lambda r} dr = \frac{4\pi \rho_0}{\lambda}[/tex]
We get a finite quantity.
Notice that this kind of structure is similar to what we really have. In our immediate vicinity, density of stars is very high. 1 star for a moderately small volume. As we look at the scale of the galaxy, the density is significantly lower. If we look at local group, the density of stars is much lower, on average, than in a galaxy. And so on. This sort of fractal structure allows for a finite amount of light to be reaching us from the sky despite effectively infinite number of stars out there.
Note that stellar dust would not make a difference. If stars were uniformly distributed, interstellar dust would reach thermal equilibrium with the stars and would glow just as hot.
The Cosmic Energy Inventory
dark matter: ##0.23 \pm 0.03##
primeval thermal remnants -> electromagnetic radiation: ##10^{-4.3\pm 0.0}##
poststellar radiation: ##10^{-5.7\pm 0.1}##
Radiation is 4 orders of magnitude below dark matter.
The upper limit on a photon mass, according to the http://pdglive.lbl.gov/popupblockdata.brl?nodein=S000M&inscript=Y&fsizein=1 , is <10-18 eV (or <10-26 eV with a specific model). This corresponds to 2*10-54kg as upper limit per photon.
You got me! I chose numbers that, although widely available in the public domain, gave the me answer that I wanted.
btw, great links - thanks
Thanks very much for the reply, but I have a problem with this line
Are you not arguing a flux here? (i.e. Gauss ) What happens to the photons once they have reached a destination?
While individual photons will be absorbed, won't the total number available will remain constant?
Sorry if that's a little confusing, but, again, thanks for the reply - it's very interesting.
the light from each ring that reaches Earth will be the same. And we are adding up an infinite amount of rings. the intensity falls off as 1/r^2 but the further we go out
there will be r^2 more stars to add to the light so the light from each ring will be the same no matter the distance.
1. What is "Handwaving to match orders of magnitude"?
"Handwaving to match orders of magnitude" is a term used in science and mathematics to describe a method of estimating quantities or values by using approximate calculations based on the order of magnitude. It involves making educated guesses and using simplified equations to quickly determine if a given result is reasonable.
2. When is "Handwaving to match orders of magnitude" used?
This method is commonly used in scientific research, particularly in theoretical physics and engineering, where large and complex calculations are involved. It is also used in everyday life situations, such as estimating the number of people in a crowd or the distance between two locations.
3. What are the advantages of using "Handwaving to match orders of magnitude"?
One of the main advantages of this method is that it allows for quick and approximate calculations, which can save time and effort in complex problems. It also helps in identifying unrealistic or incorrect results, as the estimated values can be compared to the actual values to check for reasonability.
4. Are there any limitations to using "Handwaving to match orders of magnitude"?
Yes, there are limitations to this method, as it only provides approximate values and does not guarantee accuracy. It is also not suitable for precise calculations or in situations where precise values are required. It should only be used as a rough estimate or as a starting point for further calculations.
5. How can one improve their "Handwaving to match orders of magnitude" skills?
Practice and experience are key to improving one's ability to estimate values using this method. It is also helpful to have a good understanding of the problem and the underlying concepts, as well as a familiarity with common orders of magnitude and their corresponding values. Consulting with others and checking results against actual data can also help in honing this skill.
  • Atomic and Condensed Matter
  • Cosmology
  • Cosmology
