Hard Circuit simplification problem
9 replies · 2K views · last reply
rohanlol7
Everything is in the picture. Question 3(a)
This is for preparation for a contest.
Two circuit diagrams: Figure 3.1a shows a cell V1 with resistors R1, R2 and R3 and a Load between nodes A and B carrying current I; Figure 3.1b shows a Thevenin-style equivalent with Eth in series with Rth driving the Load between P and G with current Io.
http://i.imgur.com/FtiKaYw.jpg
V=IR
I calculated the total resistance of the first circuit and used that to evaluate V(AB). But this is in terms of the resistance of the load. I tried using kirchhoffs laws to eliminate it but i cannot seem to do so. Also i do not understand why there is a unique combination of R(th) and E(th) that works.
I also noticed that R(th) is in face the value of the resistance of the first circuit if the load has zero resistance but i don't understand why this is so
Look at it from the point of view of the load. And post your work to see where you get stuck...
Look up Thevenin's theorem. Eth is the Thevenin equivalent voltage and and rth is the Thevenin resistance.
Thanks ! i saw it. However i still don't understand how I'm supposed to figure that out in the problem
You have two equations (already filling in ##\ \ V_{AB} = V_{PG} = V_L \ \ ## and ##\ \ I=I_0={V_L\over R_L}\ ##) : $$
V_L = V_{th}\; {r_{th} \over r_{th} + R_L}$$ in the right diagram; and in the left diagram you have $$
V_1 \; {R_3 \over R_1 + R_3} = V_L + R_2 {V_L \over R_L} $$and your task was to work around these two equations with four unknowns to two relationships by eliminating ##V_L## and ## R_L##. Not so easy, I grant you. But thereby you prove Thevenin's theorem (as opposed to making use of it)
Thanks ! i tried something similar.
The second equation come from equating the pd across R3 right ?
Across R3 and across the series Rload and R2 as well
The right hand side of the equation represents the pd across the load and R2( right ? ) shouldn't the left hand side be v1- v1*R1/(total resistance for the circuit) ?
My bad ! Sorry. Well observed !
No problem!
God so i knew how to do it its just the maths part that's killing me. I guess i'll have to work that out slowly. Thanks!
