Hard integrals for calculus 1-2 practice
  • Level: Undergrad
  • Thread starter pakmingki
    Hard Integrals
194 replies · 215K views · last reply
Your first 2 steps are right, but it looks like you got a sign mixed up afterwards.
Are you implying that 0.5*pi - (- 0.5*pi) = pi so the answer should be pi?
If so, I will have to differ. arctan (-inf) = arctan (inf) = 0.5*pi. Remember that at tan(pi/2), (inf) and (-inf) co-occur.
You can also look at the area between y = 0 and y = arctan x. From (- inf) to 0 it is negative and from 0 to (inf), it is positive. Adding the areas you get 0.
If you still think that I am wrong, please tell me why.
Thanks
All that matters for this is [itex]lim_{n \to -\infty}(\arctan n) = \frac{-\pi}{2}[/itex] as can be seen from the graph of [itex]y = \arctan x[/itex]. If you graph the curve [itex]\frac{1}{x^2 -1}[/itex], you'll see that the area under the left side of that curve is not negative, unlike with [itex]y = \arctan x[/itex]. The curve in question is symmetrical about the y-axis, so you can reevaluate the question as [itex]2 \int^{\infty}_{0} \frac{1}{x^2 + 1} \, \mathrm{d}x[/itex] which is [itex]\pi[/itex]. Also, you can solve it without using the symmetry of the curve:
It must first be broken into two improper integrals:
[itex]\int^{0}_{-\infty} \frac{1}{x^2 + 1} \, \mathrm{d}x + \int^{\infty}_{0} \frac{1}{x^2 + 1} \, \mathrm{d}x[/itex]
The first improper integral becomes [itex]\lim_{a \to -\infty}(\arctan a) |_{-\infty}^{0}[/itex]. This becomes [itex]0 - lim_{a \to -\infty}(\arctan a) = \frac{\pi}{2}[/itex]. As for the second improper integral: [itex]\lim_{b \to \infty}(\arctan b) |_{0}^{\infty} = \lim_{b \to \infty}(\arctan b) - 0 = \frac{\pi}{2}[/itex]
So, the whole integral together does evaluate to [itex]\pi[/itex] and not zero.
hEMU said:
Wouldn't it just be zero?
-You substitute x = tan u
-You get [arctan x] from (-inf) to (+inf) which is 0
arctan(inf) = pi/2 and arctan(-inf) = -pi/2 so its [itex]\pi[/itex]
Ok I get it, thanks.(and yes i get why i was wrong)
Find the volume of the region between [itex]z=x^2+y^2-4[/itex] and [itex]z=4-x^2-y^2[/itex] on the domain [itex]x^2+y^2=4[/itex] in rectangular and cylindrical coordinates. (Do cylindrical first, it is a lot easier.)
Calculus Master said:
To integrate [tex]\int_{0}^{\infty}sin(x^2)dx[/tex] we use [tex]\int_{0}^{\infty}sin(x^n)dx[/tex] =[tex]\Gamma{(1 + \frac{1}{n})}\sin{\frac{\pi}{2n}}[/tex] = [tex]\frac{\sqrt{\pi}}{2\sqrt{2}}[/tex]
That's fantastic, thank you.
It's kind of cheating, no fun when you use formulas. I think it can be done without a formula.
Well, good luck!
Oops the domain is [itex]x^2+y^2\le 4[/itex]
Inverse trig substitution not always is a good substitution for integrals with square root of quadratic
f.e
[tex]\int{\frac{\mbox{d}x}{x\sqrt{2x^2-2x+1}}}\\\int{\frac{\mbox{d}x}{x\sqrt{2x^2-2x-1}}}\\\int{\frac{\mbox{d}x}{x^2\left(4x^2-3\right)^2\sqrt{x^2-1}}}[/tex]
If you want to get u substitution for ths integrals draw a curve [tex]y^2=ax^2+bx+c[/tex]
and cut it with secant line
If secant line intersects curve at [tex]\left(\lambda,0\right)[/tex] or [tex]\left(\mu,0\right)[/tex] you will get third substitution
If secant line intersects curve at [tex]\left(0,\sqrt{c}\right)[/tex] or [tex]\left(0,-\sqrt{c}\right)[/tex] you will get second substitution
Assume that [tex]a>0[/tex] , draw asymptote and cut the curve with lines parallel to this asymptote
This lines will intersect point [tex]\left(x_{0},y_{0}\right)[/tex] at infinity and point [tex]\left(x,y\right)[/tex] which coordinates are rational functions of new variable
You will get first substitution in this way
You can also draw right triangle and label its sides as in inverse trig substitution
Bisect one of acute angle to get new right triangle
Calculate length of missing side using angle bisector theorem
Your u substitution is tangent of acute angle in this new right triangle
yip said:
Try [tex]\int{\frac{(1+x^{2})dx}{(1-x^{2})\sqrt{1+x^{4}}}}[/tex]
(forgot to put the integral sign in, it is now fixed)
How about dividing both sides by x^2 then put x-1/x = t, 1+ 1/x^2 dx = dt
This one is really hard and you need to be good in calculus.
find $$\int^{\pi/2}_0(sinx-cosx)lnsinxdx$$
Believe me, its really difficult.
Looks like integrating by parts will take care of it.
No. That's just 5% of the solution. Its not easy.
you can separate it as integral(sinx*lnsinx dx) - integral (cosx lnsinx dx)
on right side use substitution sinx=u, and use partial integration to get answer.
on left side use substitution ln(sinx)=v and you can get answer easily with beta function after the integral becomes sin^2(x)cos^-1(x) dx.
so about 5min unless you are not fluent in these methods, or if the use of beta functions is not allowed.
I knew you would come up with that method. You are wrong.
REASON: limits.
Your answer will be filled with -infinity terms.
You cannot get the answer because the function gives infinity in lower limit. If it was an indefinite integration, your answer would have been right.
I said its a difficult question. Think again.
REASON: limits.
how? on the left integral, from the beta function you will get gamma functions and no limit problem there.
on the right side there is no limit problem either because it will become integral (ln (u)) which will integrate to u*ln(u)-u, and replacing u=sinx and it's trivial.
I need a numerical answer to question in post #135. Its not easy.
I have really difficult questions. The one at #135 is the easiest of them.
Don't compute the indefinite integral. The tricky part is the limits.
Ok. Substitute limits and post the answer.
log(2) which is about 0.693 . have a good day
Or this one
##\int_0^{\pi/2}sinxlnsinxdx##
Now you can't split the integral.
yeah I am not going to do your homework :P
but I can encourage you by telling that they are simple, and if you know how to get log2, you will know how to solve the sinx lnsinx dx integral because it is part of the previous problem
You solved them using beta or gamma functions which we are not taught in school. In school level, if you did not know such functions, then it will be difficult to solve such problems. And don't say they are easy. These questions are made by a mathematician who has a PhD in maths, which you probably don't have. And the level of questions are not easy.
Also, these are not homework questions. If you want you can try them out :P
Its for those who like solving integration problems.
You don't need special functions to solve the integrals.
Yes the limits are not directly computable, however simply taking their limits works.
And, why are you so hostile?
I was trying to make things interesting. I like competion irrespective of success or failure.
