Have you seen this prime number equation?
  • Thread starter Thread starter ArcanaNoir
    Prime
The discussion centers on a prime number equation proposed by a professor, which states that an integer p is prime if and only if there exists a unique pair of natural numbers m and n such that 1/p = 1/m - 1/n. The equation can be rearranged to show that m = p - 1 and n = p(p - 1) for any prime p. The uniqueness of m and n is confirmed through a proof that utilizes properties of prime numbers and their factors, demonstrating that for prime k, the pairs (m, n) are indeed unique.
  • Understanding of prime numbers and their properties
  • Familiarity with basic algebraic manipulation of equations
  • Knowledge of greatest common divisor (gcd) and least common multiple (lcm)
  • Basic concepts in number theory
  • Study the properties of prime numbers in depth
  • Learn about the greatest common divisor (gcd) and least common multiple (lcm) in number theory
  • Explore advanced topics in number theory, such as unique factorization
  • Research methods for verifying mathematical conjectures and theorems
Mathematicians, number theorists, educators, and students interested in prime number properties and mathematical proofs.
ArcanaNoir
One of my professors told us about a prime number equation he came up with back in his own college days in Russia. It was published in a Russian journal in the problems section years and years ago and has not been translated to English. The thing is, his professor thought this equation must have already been presented somewhere. My professor could not find it anywhere. I can not find it. But it does seem like the kind of thing that should already have been said. So I'm wondering, has anyone seen this equation before?
an integer p is prime iff there exists a unique m and a unique n (m and n are natural numbers) such that: 1/p = 1/m - 1/n
I'm not familiar with it.
To unpack it a little,
\frac{1}{p}=\frac{1}{m}-\frac{1}{n}\quad\to\quad p=\frac{n\,m}{n-m}
Added in Edit:
I did notice the following:
\frac{1}{p-1}-\frac{1}{p}=\frac{1}{p^2-p}
So for any prime p, it's easy enough to find m & n:
m = p - 1
and
n = m p = p(p-1).
Are those (m & n) unique for all primes?
Well, m and n depend on each other, so I can say at least that it is a unique pair. And m can be expressed depending only on p, so for each p a unique m. The same for n, it can be expressed in terms of p, so for each p a unique n. So, yes, if I understand the question correctly.
The fact is that for any natural number k > 1, it's true that:
\frac{1}{k-1}-\frac{1}{k}=\frac{1}{k^2-k}\quad\to\quad\frac{1}{k}=\frac{1}{k-1}-\frac{1}{k^2-k}
So that m = k - 1 and n = k(k-1). According to your professor's conjecture, if k is prime, then n and m are unique. Also, according to the conjecture, if k is not prime, then there must be at least on other pair of natural numbers which give 1/k in the prescribed way.
It turns out to be easy to show that if k is not prime, then the m, n pair are not unique.
EDIT: Sorry for the latexfail, my post didn't seem to be compiling right and I was too lazy to figure out why so I just deleted all the latex code.
Here's a proof that m and n are unique when k is prime:
****Spoiler Alert****
Let m and n be natural numbers such that (1/m) - (1/n) = (1/k), and suppose that k is prime. Rearranging gives
(1) mn = (n - m)k.
Let d = gcd(m,n), and suppose that m = da, n = db, where gcd(a,b) = 1. It is well-known that the identity gcd(m,n) * lcm(m,n) = mn holds for all integers m,n; thus, since lcm(m,n) = dab, we can divide the above relation by d to get
(2) dab = (b - a)k.
However, since gcd(a,b) = 1, we have gcd(a, b - a) = gcd(b, b - a) = 1. In general, if an integer x divides a product of integers yz with gcd(x,y) = 1, then necessarily x divides z . In this case, it follows that a and b divide k . Since k is assumed prime, we have three cases: Either a = b = k , in which case the right-hand side of (2) vanishes (contradiction); or a = b = 1, which has the same problem; or a = 1, b = k (the sign is wrong if a = k, b = 1 ). Plugging this into (2) gives d = k - 1. Putting things together, we see that m = da = k - 1 and n = db = k(k - 1) = k^2 - k, which is the solution that has already been pointed out. This completes the proof.
I came up with a slightly different proof (really, I think, just different formulation) of the proof that m,n are unique for p prime.
First, note a few obvious facts from the problem statement (m,n natural numbers):
n > m
0 < m < p
0 < p-m < p
p = nm / (n-m)
n = pm / (p - m )
Considering the last of these formulas, if p-m=1 we have the universal solution m=p-1, n=p(p-1). So we inquire about a case where p-m > 1, thus 1 < p-m < p, and 0 < m < p-1. Since we assume p prime, we must have p-m a factor of m (from last formula). Thus:
m = k (p-m) [1]
which gives:
p = (k+1)m/k
k and k+1 can only have 1 as common factor (suppose qr=k; smallest possible way to use q as factor of k+1 is q(r+1) = qr + q = k+q > k+1 unless q=1). Therefore k must be a divisor of m (including 1 as possibility). But if m/k > 1, we have a factorization of p. Thus k=m. But this leads, from [1] above, to 1 = p-m, which contradicts our assumption that p-m > 1. QED.
Just for completeness, I note that for any p, if ab=p,
m = p-a
n = b(p-a)
is a solution, allowing at least a=1,b=p plus some other solution for p not prime.
This is a really cute prime property which is new to me (but then, I never studied any number theory).
Is there anyway to verify that it hasn't been published elsewhere, or at least be reasonably confident? I mean other than scouring actual paper between bindings. Like, a way to google it or something? My google attempts weren't getting the message across to the system. Perhaps I don't know what syntax would be clear to it.
This theorem (or conjecture) doesn't look all that useful to me. After all, for any integer, k>1, letting m = k-1, and n = k(k-1) gives \displaystyle \frac{1}{k}=\frac{1}{m}-\frac{1}{n}\,. Determining whether these are the only values of m & n which give k in this way, seems to be at least as difficult as any other method for check the primality of k.
I don't think the point is to use it for a prime check. You're right, that would be less than efficient. I think it's just an exploration of primes and falls more toward number theory.
Well, yes, it is a nice proof to work out in a number theory class.
  • · Replies 16 ·
