Heat Capacities Given Equation of State
The discussion focuses on deriving the equation of state and calculating heat capacities for a system defined by the equation ##V(P,T)=V_1\cdot exp(\frac{T}{T_1}-\frac{P}{P_1})##. The derived pressure equation is ##P(V,T)=P_1\cdot (\frac{T}{T_1}-ln(\frac{V}{V_1}))##. The entropy is calculated as ##s = \frac{1}{3}DT^3 + \frac{P_1}{T_1}V + s_0##, leading to the heat capacity at constant pressure, ##C_P = DT^3 + \frac{P_1V_1T}{T_1^2}exp(\frac{T}{T_1}-\frac{P}{P_1})##. The final calculations confirm the correctness of the derived expressions.
  • Understanding of thermodynamic equations of state
  • Knowledge of heat capacities, specifically ##C_V## and ##C_P##
  • Familiarity with Maxwell's relations in thermodynamics
  • Proficiency in calculus, particularly partial derivatives
  • Study the derivation of Maxwell's relations in thermodynamics
  • Learn about the implications of different equations of state on thermodynamic properties
  • Explore advanced topics in heat capacity calculations
  • Investigate the applications of entropy in thermodynamic systems
Students and professionals in thermodynamics, physicists, and engineers involved in heat transfer and energy systems will benefit from this discussion.
Yoni V
Given the equation of state ##V(P,T)=V_1\cdot exp(\frac{T}{T_1}-\frac{P}{P_1})## where ##V_1\;,T_1\;,P_1## are constants:
a. derive an equivalent equation ##P(V,T)##;
b. given ##C_V=DT^3## where D is a const, calculate the entropy of the system ##s(V,T)## up to a const;
c. find heat capacity ##C_P##.
Definitions of heat and heat capacities.
First law? Enthalpy?
Starting with a, we get via a simple calculation ##P(V,T)=P_1\cdot (\frac{T}{T_1}-ln(\frac{V}{V_1}))##.
Then, using heat and heat cap. definitions we get
$$ds=dQ/T=CdT/T$$$$\Rightarrow (\frac{\partial S}{\partial T})_V = \frac{C_V}{T} = DT^2$$$$\Rightarrow s = \frac{1}{3}DT^3 + S_0$$
Of this step I'm not entirely sure. It looks okay, but s is not a function of the volume, and I think I need that dependence to work out ##C_P##. So this is where I'm stuck.
Thanks!
What is the partial derivative of entropy with respect to volume at constant temperature?
Hmm... from Maxwell's relations $$(\frac{\partial S}{\partial V})_T = (\frac{\partial P}{\partial T})_V$$
which equals ##\frac{P_1}{T_1}## from the given equation of state, and then $$s = \frac{P_1}{T_1}V + s_0'$$
The heat cap. is given by ##C_P = T(\frac{\partial s}{\partial T})_P##.
I could try rewriting $$(\frac{\partial s}{\partial T})_P = -\frac{(\frac{\partial P}{\partial T})_s}{(\frac{\partial P}{\partial s})_T} = -\frac{(\frac{\partial S}{\partial V})_P}{(\frac{\partial P}{\partial s})_T}$$
But I can't see how these changes in variables get me where I want to go.
Maybe I can somehow relate ##s_0## to ##s_0'##, but it doesn't seem relevant...
What happened to the DT3/3?
Ok, I think I got it while writing this reply. What I started typing is:
It's part of the constant of integration ##s_0'##, or if we neglect a constant that has nothing to do with the temp. and volume, it is exactly ##s_0'##.
This I understand, but even writing it explicitly, I'm not sure on how to differentiate the entropy with respect to the temp. while holding P const, as V is free to change to keep the given pressure constant.
But..! We are given V in terms of both T and P. So plugging it to s, we finally get $$s = \frac{1}{3}DT^3 + \frac{P_1}{T_1}(
V_1⋅exp(\frac{T}{T_1}−\frac{P}{P_1}))+s_0$$ where ##s_0## is now a true constant that we can entirely ignore and differentiate happily to get $$C_P = T(\frac{\partial s}{\partial T})_P = DT^3 + \frac{P_1V_1T}{T_1^2}exp(\frac{T}{T_1}-\frac{P}{P_1})$$
Is that correct?!
And thank you very much!
Is that correct?!
Correct. Nice job.
