questionboy
- 3
Does anyone know the proper way to do this?
The discussion revolves around methods for heating a car engine on cold mornings, particularly in extreme winter conditions. Participants share various tips, experiences, and equipment related to engine heating, battery maintenance, and insulation techniques.
Participants do not reach a consensus on the best method for heating car engines in cold weather. Multiple competing views and personal experiences are presented, leading to an unresolved discussion regarding the effectiveness of various techniques.
Participants mention specific temperature ranges and conditions, indicating that the effectiveness of heating methods may depend on individual circumstances, such as the age of the battery and the specific vehicle model.
Individuals living in cold climates, car enthusiasts, and those seeking practical advice on maintaining vehicle performance during winter months may find this discussion relevant.
DaveC426913 said:Hm. So I guess my method of hanging a 100W lightbulb in my engine when it's in the driveway is just foolin' myself.
This is the method I used - and it worked - especially when the temperature was -20 to -30 F. I put a hang-light/lamp under the car. I put a blanket over the hood in order to insulate the engine. The blanket (or tarp) draped over the car such that it also prevented a breeze from blowing under the car.DaveC426913 said:Hm. So I guess my method of hanging a 100W lightbulb in my engine when it's in the driveway is just foolin' myself.
I am the other type of Canuck.Danger said:It's better than nothing.
I thought that you were a fellow Canuck.![]()
DaveC426913 said:I am the other type of Canuck.
I'm in Toronto. I wear a black leather jacket and I get snow tires the day after the snowfall. If power ever goes out, I will die.
GeorginaS said:And your mayor may call in the army to plow the roads.
questionboy said:Im only talking about -3 Celsius or 26Fareinheit here on an old car at worst and only at the coldest part of the morning. The temperature will rise up to 20 Celsisus during the day. Like desert temperature in winter.
mgb_phys said:At non-canuck temperatures it's mainly the battery that's the problem.
Block heaters stop the oil freeing at -40 but at -3 you are probably just loosing some battery power (especially if it's old).
Easiest way is to wrap the battery in insulation, you can buy insulated battery covers in cold places but reflective foil covered building insulation material will work, it's cheap and fireproof.
You could also add a garden heater, these are 6in square (or so) sticky pads used for keeping frost off planters in a greenhouse. They run off household current and take 20-100W depending on size.
Under the oil pan with the bulb close but not touching. In my experience, the whole engine compartment under the bonnet was quite warm, even when the car chassis was near freezing and the ambient air was at or below freezing.questionboy said:Where is the exact spot under the bonnet I should put the bulb?
Borek said:In good old days when I was driving http://en.wikipedia.org/wiki/Fiat_126 I used to put electric space heater (fan type) just under the bonnet1.5 kW for 30 minutes and I was starting it even below -20 deg C.
