Heat equation in the first quadrant.
2 replies · 3K views
A_B
Solve the heat equation [itex]u_t=u_{xx}+u_{yy}[/itex] fot [itex]t>0[/itex] in the first quadrant of [itex]\mathbb{R}^2[/itex]. The boundary conditions are [itex]u(0,y,t)=u(x,0,t)=0[/itex] and the initial temperature distribution is
[tex] f(x,y)=<br /> \begin{cases}<br /> 1 \;\;\;\; \text{in the square } \; 0<x<1; \; 0<y<1 \\<br /> 0 \;\;\;\; \text{elsewhere}<br /> \end{cases}[/tex]
I can solve problems in finite domains, ie where enough boundary conditions are given to determine the countable infinite set of eigenvalues. This problem is on a semi-infinite domain, with insufficient boundary conditions to do so. I have come to understand that to solve such a problem, one replaces "the sum over eigenvalues" with an integral of the solutions obtained by separation of variables, over the (roots of the) eigenvalues.
This is where I got (detailed derivations not typed out)
Separation of variables (solutions of the form [itex]u=X(x)Y(y)T(t)[/itex] gives ODEs
[tex] \begin{cases}<br /> -\ddot{X} = \lambda_1 \;\;\;\;\;\;\;\;\;\;\;\; X(0)=0\\<br /> -\ddot{Y} = \lambda_2 \;\;\;\;\;\;\;\;\;\;\;\; Y(0)=0\\<br /> \dot{T}=-(\lambda_1+\lambda_2)T<br /> \end{cases}[/tex]
The "eigenvalues" can be shown to be all positive. So let [itex]\lambda_1 = \gamma_1^2[/itex] and [itex]\lambda_2 = \gamma_2^2[/itex]. With [itex]\gamma_1[/itex] and [itex]\gamma_2[/itex] both positive.
The solutions are
[tex] X(x)=\sin(\gamma_1 x) [/tex]
[tex] Y(y)=\sin(\gamma_2 y) [/tex]
[tex] T(t) = e^{-(\gamma_1^2 + \gamma_2^2)t}[/tex]
So the solution for separated variables is
[tex] u(x,y,t)=\sin(\gamma_1 x)\sin(\gamma_2 y) e^{-(\gamma_1^2 + \gamma_2^2)t}[/tex]
Since there are solutions for every positive [itex]\gamma_1[/itex] and [itex]\gamma_2[/itex], we can't determine eigenvalues like in regular problems. We write the final solution as a weighed integral of the solution for separated variables, with respect to the gamma's.
[tex] u(x,y,t) = \int_0^\infty\int_0^\infty d\gamma_1 d\gamma_2 \alpha(\gamma_1, \gamma_2) \sin(\gamma_1 x)\sin(\gamma_2 y) e^{-(\gamma_1^2 + \gamma_2^2)t}[/tex]The function [itex]\alpha(\gamma_1,\gamma_2)[/itex] is determined by the initial conditions:
[tex] f(x,y) = u(x,y,0) = \int_0^\infty\int_0^\infty d\gamma_1 d\gamma_2 \alpha(\gamma_1, \gamma_2) \sin(\gamma_1 x)\sin(\gamma_2 y) [/tex]
And here I'm stuck, how do I determine alpha?Any help is much appreciated,
A_B
I solved it, the last formula expresses f(x,y) as a double Fourier sine transform of α(γ_1, γ_2). So taking the inverse Fourier sine transform of f(x,y) twice gives α.
A_B
