What is the Inequality for the Heat Equation?
The discussion focuses on deriving an inequality for the heat equation, specifically analyzing the expression obtained by multiplying the heat equation by 2u. The participants explore integrating the resulting equation and establishing that the integral of u² over the interval [0, 1] is a decreasing function. They conclude that this integral is always less than or equal to its initial value, leading to the proof of the inequality. The discussion also touches on the uniqueness theorem, indicating that the solution to the heat equation with specified boundary conditions is unique.
  • Understanding of the heat equation and its properties
  • Familiarity with integration techniques in calculus
  • Knowledge of boundary conditions in differential equations
  • Experience with uniqueness theorems in mathematical analysis
  • Study the derivation of inequalities related to the heat equation
  • Learn about boundary value problems and their solutions
  • Explore uniqueness theorems in the context of partial differential equations
  • Investigate the implications of the maximum principle for parabolic equations
Mathematicians, physicists, and engineers working with heat transfer problems, as well as students studying partial differential equations and their applications in real-world scenarios.
mmmboh
So I multiplied the heat equation by 2u, and put the substitution into the heat equation, and get 2uut-2uuxx=(u2)t=2(uux)x+2(ux)2.
I`m not sure where to go from there, I can integrate with respect to t, then I would have a u2 under the integral on the left side, but them I`m not sure where to go.
I also tried using the fact that the solution to the heat equation is
And I said that the integral was less than
\int_{-infinity}^{infinity} \ f(y)dy
and then I squared both sides, and said that the integral squared was less than the square of the integral. Then I integrated both sides with respect to x, but the problem is now, I have a double integral on the right side :S.
I think the idea is to derive a differential equation for the integral of u^2 w.r.t x from 0 to 1.
:cry: How do I do that?
To start with, use the hint and integrate over x from 0 to 1 and what do you get?
I think the idea is to show that:
<br /> \int_{0}^{1}u^{2}(t,x)dx<br />
is a decreasing function and so it will always be less than or equal to it's initial value, and so you get the inequality you are asked to prove.
<br /> \int_{0}^{1} \ (u^{2})_{t}dx = 2uu_{x}(1,t)-2uu_{x}(0,t)-2<br /> \int_{0}^{1} \ (u_{x})^{2}dx<br />
This is what I get.
Riiiight, I got the following equation:
<br /> \frac{\partial}{\partial t}u^{2}=2\frac{\partial}{\partial x}\left( u\frac{\partial u}{\partial x}\right) -2\left(\frac{\partial u}{\partial x}\right)^{2}<br />
Integrate this w.r.t. x from 0 to 1 and what do you get?
I fixed my equation, any way that`s what I get, but I don`t see what to do with it.
Do as I said and integrate to obtain:
<br /> \frac{\partial}{\partial t}\int_{0}^{1}u^{2}dx=2\left[ u(t,x)\frac{\partial u}{\partial x}(t,x)\right]_{0}^{1}-2\int_{0}^{1}\left(\frac{\partial u}{\partial x}\right)^{2}dx<br />
Now the stuff in the square brackets vanishes (why?). So what can't we say about:
<br /> \int_{0}^{1}u^{2}dx<br />
? My equation is the same as yours, I just used subscript notation. If the stuff in the square brackets vanishes, then as you change t, <br /> <br /> \int_{0}^{1}u^{2}dx<br /> <br /> decreases, so it will be smaller than <br /> <br /> \int_{0}^{1}f(x)^{2}dx<br /> <br />
since this is when t=0. Is that right?
Edit: The term in the square brackets vanishes because u(1,t)=u(0,t)=0.
So what would the uniqueness theorem be then? It`s always decreasing with respect to t, and u(x,t)=f(x) only once? I`m not sure.
We're told that in the question, u(t,0)=u(t,1)=0.
Finally, you have the solution, but formally, i would say that:
<br /> \frac{\partial}{\partial t}\int_{0}^{1}u^{2}dx=-2\int_{0}^{1}\left(\frac{\partial u}{\partial x}\right)^{2}dx\leqslant 0<br />
as the quantity in the integrand in positive, so the integral will be positive which shows that the quantity we spoke about is clearly decreasing.
Thank you. You have been a great help. What do you think of my uniqueness theorem though? It does not seem like much of a theorem.
Edit: I guess it means that since the integral is decreasing, the solution to the heat equation with a boundary condition is unique...
I edited my post.
The usual way for uniqueness theorems is to assume that there are two solutions u_1 and u_2 and examine the quantity w=u_1-u_2 and show that the only possible case is w=0.
