Heat Equation Initial Conditions
The discussion revolves around solving the heat equation ut=uxx with specified boundary conditions: u'(0) = 0 and u(L) = 0. The initial condition provided is u(x,0) = 1 for 0 < x < L/2 and u(x,0) = 0 for L/2 < x < L. Participants clarified the correct interpretation of the boundary and initial conditions, emphasizing the need to express them accurately for effective problem-solving. The solution involves using Fourier series to address the eigenvalue problem derived from the boundary conditions.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with boundary value problems
  • Knowledge of Fourier series
  • Basic concepts of eigenvalue problems
  • Study the method of separation of variables for PDEs
  • Learn how to apply Fourier series to solve initial-boundary value problems
  • Explore eigenvalue problems in the context of heat equations
  • Review the implications of boundary conditions on solution behavior
Mathematicians, physics students, and engineers dealing with heat transfer problems, particularly those working with partial differential equations and initial-boundary value problems.
EsponV
Greetings all,
I have a question in regards to my initial conditions. The problem as given is:
ut=uxx with u' = 0 at x=0 and u=0 at x=L
I was also given u={1 0<x<L/2, 0 L/2<x<L
I understand the set up of the problem and the solving of it for the most part, however I'm having trouble understanding the point that the third condition (the one about u) makes. More or less I'm stuck with trying to figure out what X is initially.
Thank you
EsponV said:
Greetings all,
u' = 0 is ambiguous; this is a partial differential equation, and these are boundary conditions. I assume you mean:
ux(0,t) = 0, u(L,t) = 0 for t > 0.
Ditto here. Write it correctly:
u(x,0) = 1, 0<x<L/2, 0 L/2<x<L
Thank you
Your two boundary values for x should give you an eigenvalue problem after you separate variables. The last condition, which is an initial condition, tells you the initial temperature of the bar at t = 0. You should be able to satisfy that using Fourier series from your eigenvalue problem.
Thank you for your help. My teacher had written up our homework in the form that I wrote it in originally, and thus I was having trouble trying to figure out what the initial conditions were exactly. Your post clarified it, and I should be set to solve it now.
Thanks
