plucker_08
- 54
- 0
is there such thing as condenser/evaporator capacity of an aircon?
how to compute for that?
thanks!
thanks!
The discussion revolves around the calculation methods for the capacity of air conditioning heat exchangers, specifically condensers and evaporators. Participants explore theoretical and practical aspects of heat exchanger design, measurement techniques, and the impact of various conditions on performance.
Participants express a range of views on the calculation methods and theoretical aspects of heat exchanger capacity, with no consensus reached on specific formulas or approaches. The discussion remains unresolved regarding the best methods and assumptions for calculations.
Participants highlight the complexity of heat exchanger performance calculations, the need for controlled testing environments, and the potential variability in results based on external conditions. There are also mentions of missing assumptions and the dependence on specific definitions in the discussion.
This discussion may be useful for students and professionals involved in HVAC system design, heat exchanger technology, and thermal engineering, particularly those interested in practical applications and theoretical calculations related to heat transfer.
plucker_08 said:how can i measure the pressure inside the inlet of a tube?
You solder a coupling with a pressure port onto the tube.plucker_08 said:do i have to bore the tube or just place the transducer around the pipe.?
momentum_waves said:Plucker_08, if this is an industrial application, then I'd suggest that you employ the services of a professional consultant.
If this a student project, then you will have a lot of reading to do.
These are simple facts of life. Some consultants have spent years researching & applying the principles in practice. This comes at a price, unfortunately - time <=> money.
russ_watters said:You solder a coupling with a pressure port onto the tube.
velz said:i want to calculate the mass flow rate of hot water in the heat exchanger?
my known datas are...
In the first heat exchanger exhaust gas flows with 650 c temperature inlet and mass flow rate is 18.7 m3/min
In the second heat exchanger hot water flows with 27 c temperature inlet and 90 c temperature outlet......
here i want to calculate mass flow rate of hot water in the second heat exchanger?
and how to calculate cp value for both exhaust gas and water?
russ_watters said:There is a theoretical maximum capacity of any heat exchanger, based on the delta-T and flow rates of the fluids on each side of it.
