Heat kernel as Green's function for the heat equation
6 replies · 4K views
lriuui0x0
TL;DR
Trying to understand heat equation general solution through Green's function
Given a 1D heat equation on the entire real line, with initial condition ##u(x, 0) = f(x)##. The general solution to this is:
u(x, t) = \int \phi(x-y, t)f(y)dy
where ##\phi(x, t)## is the heat kernel.
The integral looks a lot similar to using Green's function to solve differential equation. The fact that ##\phi(x, 0) = \delta(x)## also signals something related to Green's function. This wikipedia page talks about Green's function related to heat equation as well.
However after searching on the internet, I don't get how do I understand the Green's function in the context of heat equation. As I understand, Green's function is related to a particular ordinary linear differential operator. What's the differential operator for heat equation?
lriuui0x0 said:
Summary:: Trying to understand heat equation general solution through Green's function
Have you had a look at
http://web.pdx.edu/~daescu/mth428_528/Green_functions.pdf
First, as others have noted, Green's functions are used for partial differential equations all the time, not just ordinary differential equations.
Your particular problem is ##u_t - u_{xx} = 0## with ##u(x,t=0) = \delta(x)##, for ##-\infty<x<\infty##.
This is equivalent to the problem ##u_t - u_{xx} = \delta(x) \delta(t) ## with ##u(x,t<0) = 0##, for ##-\infty<x<\infty##. The solution to this problem is the Green's function for the operator ##L(u) = u_t - u_{xx}##.
So in this case the homogeneous initial value problem is equivalent to a non-homogeneous problem with zero initial conditions.
Was that the connection you were looking for?
jason
jason
Thanks!
