Heat Q flows spontaneously from a reservoir at 383 K into a reservoir
  • Thread starter Thread starter copitlory8
    Heat
The problem involves heat transfer between two reservoirs, one at 383 K and another at an unknown lower temperature T. It discusses the implications of spontaneous heat flow and its effect on the efficiency of a Carnot engine operating between these two temperatures, with a specific focus on the percentage of heat rendered unavailable for work.
  • Participants explore the relationship between the heat flow and the efficiency of the Carnot engine, questioning how the unavailability of heat affects the work output. There is discussion on the interpretation of the 30% unavailability and its implications for the efficiency calculation.
Participants are actively engaging with the problem, raising questions about the definitions and relationships between the variables involved. Some have attempted to calculate efficiency based on assumptions, while others express confusion about the implications of the given temperatures and the meaning of the percentages stated in the problem.
There is uncertainty regarding the interpretation of the problem, particularly concerning the relationship between the total heat Q and the heat Q' used by the Carnot engine. Participants note that the problem may not provide sufficient information to arrive at a clear solution, leading to varied interpretations of the efficiency and the temperatures involved.
  • #31
well i understand but my teacher is really smart. and the way webassign works is that is has a huge databank of questions released from my textbook publisher and it picks questions randomly. so my teacher hasn't even seen all the questions so once in a while a tough one appears such as this one. can someone seriously just tell me the solution
  • #32
No, we will not just give you the solution. If you think you deserve to be just given the answer, ask your teacher. Instructors who use WebAssign have access to a complete answer key, and in some cases explanations of how the problems are solved.
As long as you are willing to continue to make an effort on the problem, we can do our best to guide you through it.
