Heat sinking to Aluminum block and dissipation
This discussion focuses on estimating heat sinking and dissipation in an aluminum structure for cooling a hot liquid. The setup involves a maximum power input of 1000W, with an aluminum structure of approximately 30 cubic inches and a surface area of 352 square inches. Key calculations include determining the U value, which is established at 36 BTU/ft²°F, and understanding the relationship between temperature gradient (ΔT) and heat loss. The discussion emphasizes the importance of specific heat tables for aluminum and the need for potential forced air cooling to enhance heat dissipation.
  • Understanding of thermal conductivity and heat transfer principles
  • Familiarity with specific heat capacity, particularly for aluminum
  • Knowledge of U value calculations for heat dissipation
  • Basic thermodynamics related to temperature gradients (ΔT)
  • Research specific heat tables for aluminum to understand thermal properties
  • Learn about calculating U values for different materials and conditions
  • Investigate forced air cooling techniques to improve heat dissipation
  • Explore thermal management strategies for liquid cooling systems
Engineers, thermal management specialists, and anyone involved in designing cooling systems for high-temperature applications will benefit from this discussion.
fastline
I am curious if someone can help be estimate heat sinking and dissipation in an Aluminum structure? What I am trying to do is is cool a hot liquid by just allowing it to heat the structure it is in since there is a reasonable amount of mass. Though the Aluminum structure is not designed specifically to dissipate, this becomes just a function of dT and surface area mostly.
power in is about 1000w max, structure is estimated at about 30 ci, and 352in2 of area. There is not active fan but that can be added really needed. Ambient temp not to exceed 110F and structure temp just should not "burn you". Vague, I know...
I am just trying to figure out the energy required to heat the structure, and it's ability to dissipate the heat.
Science news on Phys.org
As a start, you'll need to look up tables of specific heat, to find the value for aluminum.
You can figure out how much heat energy is contained in the hot liquid by multiplying its temperature by its specific heat by its mass.
Thanks for that. From the calcs I have run, this structure of Al will not hold much energy as heat.
However, more importantly, the dissipation. I determined the U value as 36 (btu/ft2 F)but I cannot remember if I would use the dT above ambient? IE Ambient is 100F structure is 110F, surface area is 2.5ft2 so heat loss is 900btu?
Determining forced air U values seems much more complex so I am just trying to roughly estimate that.
Power = UValue * Area * ΔT
where ΔT is the temperature gradient between the same two points used to calculate the UValue.
  • · Replies 20 ·
  • · Replies 26 ·
