Heat transfer and turbine blade
The discussion centers on the challenges of analyzing temperature distribution in a 2D turbine blade with varying hole diameters for cooling passages. Participants emphasize that analytical heat transfer methods are insufficient for complex geometries, recommending the use of Finite Element Analysis (FEA) and computational fluid dynamics tools like ANSYS FLUENT for accurate results. They highlight the importance of validating numerical models with empirical data and real testing to ensure reliability in turbine cooling solutions.
  • Understanding of Finite Element Analysis (FEA)
  • Familiarity with ANSYS FLUENT for computational fluid dynamics
  • Knowledge of heat transfer principles, particularly in complex geometries
  • Experience with numerical modeling and validation techniques
  • Research advanced FEA techniques for thermal analysis
  • Learn how to implement ANSYS FLUENT for turbine cooling simulations
  • Study empirical data comparison methods for validating numerical models
  • Explore simplified analytical checks for initial temperature distribution estimates
Engineers, thermal analysts, and researchers involved in turbine design and cooling system optimization will benefit from this discussion.
thisdude
hi,
i was hoping someone could help me with a problem i am having. i have a 2D turbine blade, with many holes of different diameters through it that represent the cooling passages. i am trying to find an analytical solution of the temperature distribution so i can compare it with computational answers i have.
any help is much appreciated...
thanks in advance
Sounds to me like you need an FEA analysis more than an analytical approach. Analytical heat transfer just doesn't get very far on very complex geometries, it's better for use in simple geometric shapes, and 1-D approximations.
Sound like a conjugate problem you would solve using FLUENT. Analytical solutions for cooling holes don't get you very far but you can calculate the bulk flow through the passages and the ...never mind I would have no idea.
FredGarvin might know if there are standard tables for these kind of problems usually at conferences I see this kinda stuff compared against empirical data.
Nothing that I know of. The only things you can really do are very simplified analytical checks to see if you are in the ball park. From there, you need to be diligent in making sure that your numerical model converges to a believable solution. From there, real testing confirms your models and assumptions. Turbine cooling is a VERY difficult area to figure out. Us and other companies spend a lot of time and manpower on finding ways to do this.
