Heat transfer differential equation for plate temperature and input power
  • Thread starter Thread starter CyberneticsInside
    Heat Modeling Ode
6 replies · 2K views
CyberneticsInside
Member warned about posting without the homework template
Im stuck on this question, can someone please help me?
u(t) = input power [W].
x(t) = temperature in plate [Celsius]
v = 0, temperature of surroundings [Celsius]
C = 400, heat capacity for plate [J/ Celsius]
g = 2, heat transfer plate / air [W / Celsius]
Question is something like this:
You're playing with the heat plate (Kitchen). The plate might be considered like a flat heat element, that radiates heat to the surroundings.
Find a differential equation for x(t).
Nb: the change of temperature in the room migtht be neglected due to
air circulation
Should be on the form like: x'(t) = ax + bu
I assume i need to use the ΔE = W + Q, but i kind of have no clue how to even start.
I checked if there was a solutions manual but, it was partly broken. The only experience i have with modelling something with heat is the heat equation. But that's a partial differential equation, and only one-dimensional, and i 'm not sure how to handle two functions in one equation?
I know should try to come up with a possible solution, but I’ve been stuck with this all day, and I can't find any similar problems to start with either.
This is a 1D steady state heat conduction problem with heat generation within the body and a convective heat loss boundary condition at one of the surfaces. You need to perform a differential heat balance on a portion of the plate between x and x + Δx.
Ok, I think I got it.
C dx = u dt - g(x-v)dt
x'(t) = - (g / C)x + (1 / C)u
Just an additional question: Is there some better way to type in equation, like Latex or similar?
Do you see the words "LaTex / BBcode Guides" under the reply window?
Ah, found it !
So the answer would be [itex]\dot{x} = - \frac{g}{C}x + \frac{1}{C}u[/itex]
