Heisenberg Uncertainty principle in 3D
The discussion centers on applying the Heisenberg Uncertainty Principle to calculate the minimum volume in which a positron is located based on its measured velocities. The user correctly identifies the formula Δx=hbar/(2*m*Δvx) for calculating uncertainty in position but fails to incorporate the velocity values into the calculations. The user initially computes a volume of V=1.12*10-25 m³, while the correct answer is V=1.4*10-26 m³, attributed to an error in the reference material rather than a miscalculation.
  • Understanding of the Heisenberg Uncertainty Principle
  • Familiarity with basic quantum mechanics concepts
  • Knowledge of relativistic and non-relativistic physics
  • Proficiency in using physical constants such as hbar and mass
  • Study the derivation and implications of the Heisenberg Uncertainty Principle
  • Learn how to apply relativistic equations in quantum mechanics
  • Explore the significance of velocity measurements in uncertainty calculations
  • Investigate common errors in quantum mechanics textbooks and their resolutions
Students of quantum mechanics, physicists working with particle physics, and educators teaching the Heisenberg Uncertainty Principle.
mat8845
Hi there,
So here's my assignment:
''The velocity of a positron is measured to be: vx=(4.00±0.18)*105 m/s, vy=(0.34±0.12)*105 m/s, vz=(1.41±0.08)*105 m/s. Within what minimum volume was the positron located at the moment the measurement was carried out?''
I think I'm not wrong when I say that the uncertainty principle applies in every direction. Since the velocities are not relativistic, the simple equation should be:
Δx=hbar/(2*m*Δvx)
The same equation is used for Δy and Δz, and we only take the volume of the ''uncertainty box'' V=ΔxΔyΔz.
With the positron having a mass of 9.109*10-31kg, that gives me V=1.12*10-25 m3. But I know the right answer is 1.4*10-26 m3.
Even with the relativistic equations, I get the same wrong answer.
So what am I doing wrong? Note that I never used the values of the velocities. Should I use them somewhere?
Thank you for your time.
Nevermind, there was a mistake in the book.
  • · Replies 23 ·
  • · Replies 16 ·
